Which one is signal cable please show me one photo of it
  • John Galvin
    John Galvin Apr 13, 2014
    Hi tul kumari malla, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Why do I get a floating no signal pop up when cable box is on and connected to antenna coaxel cable to Coby LEDTV3256? Also channel option is inaccessible on tv screen.
You may need an HDMI plug? Please make sure you are on the correct inputs and out puts. If you can send me a photo or video? tyvm Please leave feedback
Jul 10, 2016 | Coby Televison & Video
Why does the screen turn blue and indicate "no signal"?
Hi Jocelyn,
The TV will show no signal when either there is a break in the input signal or the TV is not receiving or processing it properly. Please check the input cables and connections and the signal box. If that is ok please call the local TV tech.
May 29, 2015 | RCA Televison & Video
When i turn my monitor on it goes on and shows the acer logo then says no signal and just goes off and this just happened one day i have never had any other problems with it before
If you monitor shows no signal that means it is not connected to the computer properly and not getting any video signals from the computer. You need to check the vga cable properly Try removing the cable from both ends and and reseat the cable. Try another VGA cable. If you are using a Graphic card make sure the card is connected properly
Please feel free to get back for any further assistance.
Thank you for choosing Fixya
Jan 25, 2010 | Computers & Internet
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Lost cd-rom for canon pixma-ip 1700 photo printer. Need to reload it after computer crashed. I run on windows.
You said your computer crashed. The BIOS still records the optical drive if it connected with power and a ribbon cable.
Remove the CMOS battery and check to make sure that it reads 3.3 v. If it does, then just go into the BIOS and enable it. Save the changes and reboot.
If it doesn't show up, then either the ribbon cable or power cable came loose. Turn off the computer and make sure that the connections are tight.
If it still doesn't show up, then either the optical drive is not getting power or a signal. It can be either the drive or the cables.
Test it with another optical drive if you have a spare. If it shows up, then it is the drive. If the drive doesn't show up and was tested on another computer, then it is the ribbon or power cable.
Jul 25, 2009 | Computers & Internet
Main screen showing "no signal"
KP-43HT20 has 2 tuners, one is main (TU2) and 2nd is called sub tuner (TU1). Both tuners are mounted on A board located on right side of TV.
In my opinion, main tuner (TU2) is not working and causing No Signal message.
Let me know if you want to repair tv by yourself.to provide you more technical info.
Feb 21, 2009 | Sony KP-57HW40 57" Rear Projection...
Emachine shows no signal when turned on black screen
check your cable from the monitor to the PC , make sure they are all fully connected and try again . please post what happens
Sep 15, 2008 | E-Machines eMachines Desktop PC
Jpeg wont add to contact/2
Make sure that the contact is stored on the phone, and not the sim card.( doesn't work if its on the sim). If you have contacts on the sim and copy them in the phone they double the name, so make sure you choose the phone stored one (there is an icon before the name that shows where that contact is stored). And finally, if still nothing, try to upload .jpg extension file, because the phone resizes the picture to add it to the contact profile, so it might not support .jpeg resizing. Hope you can make it work! :)
Jan 02, 2008 | LG Prada KE850 Cellular Phone
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
