Question about Whirlpool Dryers
Timing knob isn't working in time
This follows replacing the belt and bearing. probably refitted bottom loom wire onto timing module wrong pin (used bottom {free pin?) unstead of the one up from that. Was a stalling mode on switch on a a brief smell of burning before I switched off. Seems all to work ok , turns, auto reverses etc all fine but the mechanical timer knob (module ) doesn't time down correctly now? What can I do, shall I replace the timer module?
MicrowaveSvc
  • 9098 Answers
SOURCE: Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Posted on Jan 15, 2007
  • 641 Answers
SOURCE: Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Posted on Jul 19, 2007
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
Cerfer39
  • 709 Answers
SOURCE: Hoover Condensing dryer malfunction
Hi Mike,
The motor probably has experienced locked rotor current and fried the windings. Of course the capacitor could have shorted. If you can find it, look at the capacitor and if the can looks like it's lid is swollen or pooched out, then go for replacing the Capacitor. If you remove the motor and smell the case and it smells burned, you motor is shot. It does not have to lock down to be bad. The windings do not rotate in an AC motor.
Posted on Nov 03, 2007
  • 1314 Answers
SOURCE: Burning Smell
go to the appliaces store and buy an rc4 three in one reley its simple to put on and more than likely the culpret it you have any promblems putting it on reply to me esp if the reley thats on it is white
Posted on Feb 18, 2008
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
How do u change the rod braring in a 2001 2.4 without taking out the motter ive all ready droped oil pan the timing gear holds the oil pump on do I have the take the timing cover and gears off?
remove the sump
undo the cap bolts
remove the cap
slipper bearing then slips out
push the rod up the cylinder enough to remove the slipper bearing the same way as you did for the cap
make sure that you install the slipper bearings correctly with the tab fitting into the small recess in the rod and cap
use plenty of oil on the crank pin and bearings
pull the rod back onto the crank pin
fit the cap and bolts
tension to correct tension
make sure that you can turn the crank shaft easily
NOTE ---if the crankshaft will not turn easily but appears bound up
loosen of the cap and check the bearing shell sizes are the same as the ones you replaced , you put the cap back on the right way
(Back to front will jam on the shaft) refit the sump
Oct 24, 2016 | Cars & Trucks
I have to replace the dispencer control panel (part#821074P) on Fisher Paykel e522b with water dispencer, how can i remove the front cover to get to the electronic circuit panel
Disconnect the refrigerator from the power supply.
Looking up at the dispenser, Push the 2 outer tabs upwards and gently pull the panel forward once the tabs release.
A small screwdriver or key may need to be used to dislodge the tabs from the housing.
Two locating pins on the base of the front panel hold the housing at the bottom.
NOTE: The housing cannot be removed, as wiring looms prevent its removal.
To refit new module, perform in the reverse order.
Oct 02, 2016 | Fisher and Paykel Refrigerators
Replace water pump 2004 clk500
Hi Scott, Work evolved in replacing a water pump depends on the vehicle. Some vehicles have the pump driven by the timing belt, while others drive via a 'V' belt or PK (Serpentine belt) If your is the latter, take a few photographs of the lacing for the reassembly before doing any disassembly. If it is a vehicle using the timing belt, photograph the serpentine belt and then remove it and the timing cover. Before removing the timing belt, rotate the engine to TDC and align the timing marks before taking off the belt. It is always a good idea to paint a spot of white paint onto the gears and the engine. Once the match marks have been identified and aligned, loosen the tensioner bearing fully before removing the belt. When refitting, set the marks by adjusting the belt alignment on the opposite side to the side fitted with the tensioner. Once aligned, retention and check the alignment again. If you're happy turn the engine by hand at least four times and recheck the matching up of the marks each second turn. Changing the water pump is straight forward and child's play compared to the associated work. Regards John
May 25, 2014 | Cars & Trucks
Problems with bosal towbar wiring kit....
bosal kits
claim to be plug and play to your vehicle
no wires meant to be cut
the wiring instructions might be generic and not truly specific to your C-Max
save time
wire in indicators old school
pick up the left and right indicator wires at the back of the car
make sure there is a good earth on the 7 pin plug
Mar 07, 2017 | Cars & Trucks
Bosal towbar wiring problems....
Did you ever solve the problem with the location for the orange wire as I have exactly the same problem, thanks
Apr 22, 2013 | Cars & Trucks
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
The beater bar quick working.
Remove the bottom plate and take out the beater bar plus the drive belt. Inspect the drive belt for burn marks or other damage. The bar itself is usually bound up at the bearings on each end with string, hair, and thread. Pull the bearings off, then clean the pin ends and interiors of the fixed bearings with a Q-tip and some WD-40. Oil the bearings lightly with 3-1, or similar, then reassemble the bar as it was before using a new belt if required. This process is required from time to time as the debris accumulates through use. Hope this helps!
Oct 22, 2010 | Dyson Vacuums
Timing specs for vw fox 1.8
Tune-up Specifications
Air/Fuel Ratio 0.7% Air/Fuel Ratio-Limits[1] 0.3 - 1.1% Timing[2] 6°+/- 1°BTDC Timing Advance[3] 30°+/- 3°BTDC Idle RPM[4] 800 +/- 50 [1] Check CO with the oxygen sensor connected. [2] AT 2300 RPM, and coolant temperature sensor disconnected. [3] Normal operating temperature, with coolant temp. sensor connected, at 2300 RPM. Add initial timing. [4] A/C off.
Timing mark is on flywheel, access hole is on top of bellhousing. Remove access plug with 27mm wrench if necessary
Firing Order is > 1342 Clockwise Rotation & #1 Plug Wire is at 2 Oclock on Distribitor Cap
Align the mark (can be a dot or notch) on the intermediate shaft sprocket with the notch in the crank pulley. Align the mark (can be a dot or notch) on the "Back" of camshaft sprocket with the top edge of the valve cover gasket. Be sure all the timing marks are properly aligned.
For further information refer to Timing Belt : Service and Repair
NOTE : The 8 valve engine requires a special wrench, Volkswagen No. US4493 or equivalent, to adjust the camshaft drive belt tensioner. Whenever the drive belt is removed and refitted, the camshaft and intermediate shaft timing MUST be adjusted. The drive belt can be replaced without removing the belt sprockets.
  1. Loosen alternator adjusting bolts and remove the fan belt.
  2. Remove the water pump pulley bolts and remove the pulley.
  3. Remove the upper timing cover bolts and remove the cover.
  4. Remove the timing belt guide, if equipped.
  5. Turn the engine by hand to set the No. 1 piston at Top Dead Center (TDC) and remove the crankshaft pulley.
  6. Remove bolt and nuts securing the lower timing cover and remove the cover. CAUTION: Turning the camshaft or crankshaft with the timing belt removed may cause damage to pistons and/or valves.
  7. Loosen timing belt tensioner locknut, release belt tension and remove belt from sprockets.
  8. Inspect belt for visible damage such as missing teeth or exposed threads. Inspect tensioner bearing for smooth running. Any damaged components should be replaced.
NOTE : On high mileage engines, failure of the tensioner bearing is a possibility. Consider replacing the bearing when replacing the timing belt.
  1. Align the mark (can be a dot or notch) on the intermediate shaft sprocket with the notch in the crank pulley. Align the mark (can be a dot or notch) on the "Back" of camshaft sprocket with the top edge of the valve cover gasket. Be sure all the timing marks are properly aligned.
  2. Temporarily install the crankshaft pulley to the crankshaft. Fit the timing belt starting with the crankshaft and intermediate shaft sprockets. Fit the belt so that it is as tight as possible between the crankshaft and the intermediate shaft sprockets and between the intermediate shaft and camshaft sprockets.
    1. Turn the belt tensioner clockwise to adjust the tension. The direction is important to avoid contact with the timing cover. Check the tension by twisting the belt as shown. You should be able to twist it no more than 90 degrees.
    2. Tighten the tensioner locknut to: 33 ft lbs (45 Nm)
    3. Rotate the crankshaft two revolutions and recheck the belt tension and the timing marks for proper alignment.
    NOTE: Very slight movement of sprockets and marks can be expected as belt tension is adjusted. Slight movement is OK. The smallest possible increment of adjustment is one whole tooth of the belt or sprocket.
    1. Remove the crankshaft pulley and refit the lower timing cover. Tighten the bolts to: 87 in lbs (10 Nm)
    2. Refit crankshaft pulley and tighten the bolts to: 15 ft lbs (20 Nm)
    3. Refit timing belt guide, if equipped.
    4. Refit upper timing cover and tighten bolt and nuts to: 87 in lbs (10 Nm)
    5. Refit water pump pulley and tighten the bolts to: 15 ft lbs (20 Nm)
    6. Refit fan belt and adjust tension. Tighten alternator adjusting bolts.
    Please Dont Forget To RATE ME !
Feb 09, 2009 | 1992 Volkswagen Fox
Drum Bearings replacement
This is Mogsey above, I have now renewed the bearings in my Zanussi Jetsystem 1600, Model FJD1666W. Had a man in to help. It really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! basically you have get out the residue water, release the door seal and (pipe attached) spit the m/c casing, unclip all hoses attached to drum, unclip all drum wiring ,remove belt (note position) remove motor &, lay to one side, withdraw nylon pins from shock absorbers, Look for and remove the little earthing cable set just inside the pulley rim. Carefully release drum/case supporting springs (mark positions top and bottom) and, drop drum/case onto some blocks and lift/pull/take out (really needs two people) (minding other modules). Split drum/case ring of bolts, remove front half (careful here not to damage the heater). take half containing drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper. Remove this screw (needs good quality allen key) and use wedges to the force off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum if on its side and use a heavy drift and hammer to knock through the drum spindle. Careful now to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up (ensuring protuding heater is clear of the ground!) put a large bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and inturn the drum seal) (note seal postion). Turn over the casing and knock out the outer bearing from inside the drum casing. Clean all and check condition of spider/spindle & renew if damaged. Fit the new outer bearing then the new inner followed by the seal. Dig out the old and renew the (green) O ring seal between the drum casing halves. Replace all, but give a quick test run before replacing casing to ensure belt is positioned correctly. The job would have cost £115 which I think is well worth paying someone to do.
Dec 02, 2007 | Zanussi FJD1666W Front Load Washer
Dryers Logo
22 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
