Question about DeLonghi DD50P Dehumidifier
Pump light flashing and won't turn off
Pump light flashes with pump line connected as illustrated in manual. It was working fine and pumping the water out but stopped working. It diverts the water to the tank now and I can not turn off the flashing light. How do I reset the flashing light?
SOURCE: Hi I have a delonghi
Check to see if the filter before the pump is plugged or restricted.I washed mine out with a bleach/water solution.
Posted on Jul 21, 2008
  • 30 Answers
SOURCE: the pump doesnt work
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. The line you tried to plug is probably the vent line for the pump reservoir. It attaches to a fitting on the removable tank side of the bulkhead. Unstop the vent. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a cable tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again. Newer ones have a flow direction arrow; point it away from the reservoir.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Posted on Aug 30, 2008
  • 30 Answers
SOURCE: Pump not pumping
It's not a one way valve, it's a water strainer. It has a barrel with a fitting on each end, the upper leads into the barrel, the lower has a strainer tube attached. When it's plugging up, it seems like a one-way valve because when you try to force water into the top, it pushes the lint and junk against the strainer screen, blocking it. When you try to force water in from the bottom, the water pushes the lint away from the screen, allowing a reduced flow. Some have an arrow; it's to indicate flow direction to keep the lint on the outside of the screen; the inside, being mush smaller than the barrel, would plug up much sooner. Before you replace the strainer, clean the lint & stuff out of the small pump reservoir (above the pump). If you don't, the strainer will plug up quickly again, if it can even get water to it.
Posted on Aug 31, 2008
SOURCE: de500p dehumidifier pump stopped working, help!!!
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
Posted on Apr 22, 2010
  • 4736 Answers
SOURCE: Just purchases the DD50PC. Set
The reason this happened may be two fold. Either the hose is clogged or the length of hose is to long and then has to go up hill into the slop sink. The owner's Manual says the pump is rated for an 8 foot lift. However, what I have discovered is that rating, does not take friction loss in to account.
Try moving the unit closer to the sink and shorten the hose about a foot or two. Actually, a floor drain would be perfect, if you have one in your basement.
Hope this helped you ad thanks for choosing FixYa.
Posted on Aug 07, 2011
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Sep 24, 2013 | Dehumidifiers
Condensate pump buzzes but does not remove water. have blown out discharge hose and clean check valve with changing symptons. Should I give up and put it on a box and buy a separate condensate pump or...
Edwin, according to the Owner's Manual, when this happens the drain hose is not connected properly. Turn the unit OFF and unplug it, then disconnect the hose and reconnect it. Plug the unit back in, Turn the Master ON/OFF Switch to ON and press the pump button. If the hose is connected properly, the pump should tunr on and pump the water out.
To help you further, I have included a link to the Owner's Manual for a Delonghi model like yours. Once you go to that page, click on the Acrobat Reader Icon and download the Owner's Manual. You may print it is you like.
http://www.delonghi.com/us_en/products/dd50p/
Hope this helped you. Please let me know. Thanks.
Jun 23, 2011 | DeLonghi DE500P Dehumidifier
Kenmore Dehumidifier 129-25803, Pump System malfunction
I also have a Kenmore pump system 129-25803 but I do not have the manual. I have tried to find one online but to no luck. I also called the Sears Parts & Service and they do not have a listing for this type of dehumidifier. Just wondering if you have a manual you could share? Please email me at taylor005@eastlink.ca
Jul 26, 2010 | Kenmore Dehumidifiers
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Royal Sovereign Bucketless Dehumidifier that is not running
I have had the exact same problem with my RS dehumidifier and I can tell you what the problem is not. I tried replacing the pump because I had surmised (incorrectly) that it had failed and that is why the water tray was filling up and shutting off the dehumidifier. I had also checked to see if the pump would pump water, which it would not. After scouring the internet for days and finally deciding just buying the pump itself was not an option (I was not going to spend $48 for the pump from RS since this one only lasted about a year and from what I have seen I was lucky) I decided to buy a fog machine($20 at walmart) and use the pump out of it. Spliced it in and IT WORKED GREAT. It pumped the water out and shut off when the tray was empty...just like it should. Then it turned the pump back on and off about every 3-5 seconds. After much more trial and error (more error than anything) I thought I had it figured out. When I wiped out the water tray, to the point where it was dry, the pump would not turn on until the water reached the wires. It would pump out the water and shut off the pump. AWESOME...problem solved. It then started the pump up again and it cycled about every 3-5 seconds. This would eventually burn this pump as well. The only thing left is that the control board, or some component on it, in this hunk of junk is bad. If anyone can figure out the issue with the dehumidifier wanting to turn the pump on when there is no water in the tray that would be great. I completely wiped down the tray and removed the scale build up to eliminate the possibility of that completing the circuit between the two wires.
Jul 17, 2009 | Dehumidifiers
De500p dehumidifier pump stopped working, help!!!
Jul 31, 2008 | DeLonghi DE500P Dehumidifier
Pump not pumping
Jul 02, 2008 | DeLonghi DE500P Dehumidifier
The pump doesnt work
Jun 01, 2008 | DeLonghi DE500 Dehumidifier
Open Questions:
See all DeLonghi DD50P Dehumidifier Questions
DeLonghi DD50P Dehumidifier Logo
481 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
