Question about Kenmore HE2 Plus Front Load Washer
Clothes are not getting water just hums and stops and shows f-21
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
Amana tandem 7300 washer hums but won't spin. Stopped with clothes and water in it.
If you would drain the water out with a hose (siphon it out) and remove the wet clothes, then look underneath the machine and see if you have a drive fan-belt, you may find it broken or slipping.
A very few machines have a drive shaft with a coupling instead.
God bless your efforts.
Jan 02, 2017 | Amana Washing Machines
Humming noise, then why did it stop after it was filled with clothes/water?
the noise could be a frequency vibration from the motor wanting to run but couldn't because the start /run capacitor has failed
frequency vibrations are also present if either of the water control solenoids are failing
get a service technician in to check it all out
Mar 08, 2016 | Washing Machines
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Will not go into spin cycle
machine just quit while washing the code F-21 showed up
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
