Question about Hotpoint Dryers
How ro replace hotpoint tvm560 door latch - Hotpoint Dryers
2 Suggested Answers
bloarch666
  • 17 Answers
SOURCE: my hotpoint dryer tvm560 is
WELL IF IT'S NOT A 560G THEN PROBABLY NOT TO BAD, IT'S 220 VOLT ONE LEG OF 110V RUNS THE MOTOR THE OTHER RUNS THE HEATING ELEMENT.. THE FIRST THING I WOULD CHECK IS YOUR FUSE OR BREAKER BOX, THE MOTOR WILL STILL TURN EVEN WITH ONLY 110V, IF THAT'S GOOD YOU PROBABLY HAVE A BAD COIL NOT TOO EXPENSIVE BUT KIND OF A PAIN TO INSTALL. THE SWITCHES AND SENSORS RARELY GO BAD SO I BET IT'S ONE OF THOSE TWO ISSUES, AND LAST BUT NOT LEAST CHECK AND MAKE SURE IT'S NOT ON THE FLUFF CYCLE... LOL GOOD LUCK
Posted on Jul 28, 2011
Need part number for door glass replacement Ariston ARWDF129NA
it is the whole door and glass. C00277532
check this link http://r.search.yahoo.com/_ylt=AwrBT8FtQthU9zQASwhXNyoA;_ylu=X3oDMTByMG04Z2o2BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkAw--/RV=2/RE=1423487725/RO=10/RU=http%3a%2f%2fwww.guaranteedparts.com%2fpicture_library%2fAriston%2fARWDF129NA.pdf/RK=0/RS=MKzVwRgG.yYF8eJHJVxrlf8MM_U-
Feb 06, 2015 | Hotpoint-Ariston ARWDF129NA Washer
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Hotpoint top load washer stops
Hotpoint had a habbit of skimping on the timmers on the older units. In the 80's I worker in an apartment complex and we had over 300 replaced free.
First and cheeper is to inspect the door/lid latch. If this was forced or something caught in the door when clossing, the latch switch may not be making contact and nothing runs unless the latch is "prooved".
May 20, 2012 | Hotpoint HSS25GFP Side by Side...
DOOR WONT OPEN
door latch assy replace door-latch Assembly need full model number
Jan 24, 2011 | Hotpoint Washing Machines
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Aug 22, 2009 | Washing Machines
Door does not lock shut but machine still works. Is it easy to repair?
Exactly the same happened to our Hotpoint FWD70. The spring that holds the door latch in place has snapped. I removed all screws out of the door to find the spring and the metal rod it hooks onto and bend another hook into it (I didn't have a replacement spring), put it back together and the door works fine, although for some reason the dishwasher tablet doesn't release now!!
May 19, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hi, I have a hotpoint aquarius mwa30, the door lock light flashes and/or not at all. I bought a new door interlock but it still does the same but if i link out the 2 wires in white then it tells the washer...
the spring may have gone in the latch on the door.
close the door and push the handle part by hand to move the latch into the lock more firmly.
to replace the spring or handle assembly remove the screws from the back of the door and prise the front off.
Feb 28, 2009 | Hotpoint WMA74 Front Load Washer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
