Question about Home Security
Cut composite wire that plugs into back of tv for the audio and visual cable
How do i rewire the certain colors on both the wires
    Sergeant:
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 182 Answers
Too hard nee to do your self by removing the cam.
Posted on Apr 13, 2014
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Feb 07, 2015 | Chrysler Cars & Trucks
What is the blue wire for on a samsung av cable..that has 5 connectors and is green where you plug it into the tv
What is the difference between component av cable and composite av cable
On the five wire cable, the red, blue and green are for the picture. The other two connectore are for the audio. Not all TV's have this type of input. The link above has information about the five wire and other input cables.
Jun 15, 2014 | Samsung DLP HL-P5663W 56" TV
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
THERE ARE 3 WIRES YELLOW,WHITE, AND RED WHICH WIRE I CAN DO PROPER CONECTION for get DVD WHICH JUCKS I CAN PLUG?
OK, what you have is the Composite Video cable (Yellow RCA plug) and the Audio cable for Right (Red RCA plug)) and Left (White RCA plug) audio channels. You just have to look at the back of the DVD and locate the Composite VIDEO output jack and Audio output jacks, just match the colors. Sma thing on the TV, just look for either AV1 or 2 Composite Video input jack and audio input jacks.
Set the TV to select the video source you have the cable plugged into, and that is.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 29, 2010 | Olevia LT37HVS 37 in. LCD HDTV
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
May 06, 2010 | Sony DVP-NS575P DVD Player
I get cable tv and it works fine. How do I hool up a vcr and do i have to put the tv on a certain channell for it to play . Cannot read the manual, the printing is to small.
No, the VCR hooks up Via the, sockets, Yellow, Video, and the White & Red Audio, connections, color to color. Then you select an EXTERNAL input. You do NOT "Tune" a "Channel" for this to work. It gets the signal via the Audio Visual port, usually at the side, front or rear. Also some sets can use SVHS connector. This is a small round multi pinned socket on the set, this too is an External, called composite Video. input.
Mar 17, 2010 | Televison & Video
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
Jun 04, 2009 | Lorex SG6153 / Weather Resistant Mini...
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
I am hooking up a dvd player with the black and white wires
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Mar 27, 2008 | Philips DVP5140 DVD Player
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
