Question about Keith McMillen Instruments Keith SoftStep-Multi-Touch USB Foot Controller
No power ?
Maybe a USB fuse o something, I don't know how these things work. Looking for a repairer in UK please.
  • 20 Answers
Hi There
Use the 'Google' search engine and type in keith McMillan instruments .com. who sp Indent" class="redactor_btn redactor_btn_indent" rel='nofollow' href="javascript:;">ecializes in soft step multi touch USB foot controllers, and you will definitely find the answer to your problem on this website. there is a FAQ's section and also contact details. Hope this will be helpful to you
Posted on Apr 13, 2014
1997 eclipse dash lights not working i know there are two fuse boxes i dont know which one o look at and which fuse it is help?
Your tail lights, license plate ights, and side marker lights are protected by the same fuse that supplies power to the dash lights. Hint: if your other lights are working, the fuse is NOT blown and you don't have to spend time looking for it.
The next thing that deserves mention is the fact that the dash lights are controlled by the dash light rheostat (dimmer switch). Make sure you don't have them turned off with the switch.
If after reading the above, you still think you need to find the fuse, it is fuse #5 (15 Amp) located in the dedicated fuse and relay box in the engine compartment. It is most likely marked "Taillight Relay".
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 18, 2011 | 1997 Mitsubishi Eclipse
I have a battery drain, so I tested my fuses to see if I had a short. The biggest drain in numbers on my volt meter came from the power amp fuse. fuse is unbroken. I wonder if this short was due to the...
How did you test the fuses? Fuses should be shorted. if the wire at somepoint comes in contact with ground then the current goes up and fuses blows. If your fuses are not blown then you don't have a short. You have something staying on while the car is off.
Jun 09, 2011 | Car Audio & Video
My mum's computer monitor stopped working after a power cut. When she went to turn it on there was a burning smell coming from the back and the screen stayed dark although the green monitor light stayed...
not fuse is the main capacitor is damaged and you can't replace send it to maintenance center
if you see that is helpful please don't forget to vote me
best regards
Apr 24, 2011 | Computers & Internet
The receiver turns off 2 seconds after turning power on....red light blinks
have you got all the wires wired in correctly.have you extended your speaker cables and not insulated them(wires could be touching each other).maybe a blown fuse inside.although i think if it were a fuse,it probably wouldnt light up at all.my experience with my system is that if i wire up something wrong,the power button light which is a green light,will change to red to let me know something is not right.(its warning me before i blow something up)!!yours might be doing the same thing only flickering to let you know somethings wrong.If none of this helps then you should send it in for repair.Dont be afraid to open your system and look for a glass fuse(s) about 20mm long.if you find one and its blown,then you are lucky.a blown fuse is better than a blown system
Oct 16, 2010 | Denon AVR-689 Receiver
Washing machine wont work at all
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Mar 19, 2010 | Washing Machines
Pioneer GM-7200M 800 Watt Amp shut off and wont turn back on.....
Hiya, first check by triggering or powering the amp manually by putting a voltage at the trigger. Just use a jumper from power. If the amp comes on then check the feed from head unit. Loose wire, inline fuse near the head etc.
If it still doesn't come on the hate to say its gonna have to go in for repair. Could be anything inside from protection, blown track etc.
Hope that helps
Jul 27, 2009 | Pioneer GM-7200M Car Audio Amplifier
Creative Inspire T6100 5.1 - No Power
I am facing the same problem with my creative T 6100 speakers...Please post if any solution found.....Thanks
Sep 09, 2008 | Logitech X-530 Computer Speakers
Samsung BCE1197 oven stopped working after making a noise which I think may have been the fan, maybe something caught in the fans blade or a mechanical problem, anyway I changed the fuse in the plug, still...
Since this is a UK Model, I'd suggest you contact Samsung's to find service info here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Samsung Microwave Ovens
Keith McMillen Instruments Keith SoftStep-Multi-Touch USB Foot Controller Logo
Top Keith McMillen Instruments Computers & Internet Experts
David Payne
David Payne
Are you a Keith McMillen Instruments Computer and Internet Expert? Answer questions, earn points and help others
