Question about Stihl Ms361 Carburettor
Tank vent is leaking - Stihl Ms361 Carburettor
  • Stihl Master
  • 1,807 Answers
Not a hard job to replace. Here is a link to the parts manual.
Posted on Jan 02, 2015
Leaking gas out of gas tank looks like it is missing a plug on the side of tank
I don't know your particular saw, but all fuel tanks are vented. Possibly the vent line or vent fitting has become dislodged and lost.
Sep 13, 2014 | McCulloch Garden
Gas leak where gas lines enter and leave tank
Also, make sure that the vent for the fuel tank is working. the vent is either on the fuel cap itself or thru a device commonly known as a duck bill valve, so named because of the shape of the valve. All the vent does is allow a slight amount of air to enter the tank while the trimmer is running.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
P0455 evap control system gross leak detected on 1998 volvo s70
The code means the computer tried to vent the gas tank and found a huge leak in the vent system. Issue could be a faulty gas cap, leaking gasket on the gas tank, or broken line from the tank to the vapor canister.
Sep 26, 2012 | 1998 Volvo S70
Evap control system leak detected
The code is for a small leak which could be just about anything in the system. A leaking gas cap, broken vent line from the tank to the vapor canister, leaking valve, etc.
The computer pressurizes the gas tank venting system every few minutes to check for leaks.
Sep 01, 2012 | 2003 Mazda Protege
Smell of gas and whistling sound
Its all connected.
The computer uses a solenoid to vent the fumes from the tank when the engine is running.
The vapor canister holds the fumes until the vent valve is opened.
The computer tried to vent the tank and something went wrong.
It could be from the excessive heat or something with the venting system.
A mechanic would test the venting system.
Jul 08, 2012 | 2002 Kia Sedona
My 89 nissan 240 sx fuel EVAP failed the smog test
The carbon canister may saturated. If you are one to try get as much fuel as possible into the fuel tank, that may be how it happened.
Also check the gas cap. There is supposed to be a one way valve to allow air to enter into tank, but not vent out in any direction but by the vent hose to the carbon canister. That valve may be leaking. Also, there is a purge vent to the intake manifold, check to make sure that passage is clear and not carboned up.
Feb 11, 2012 | Nissan 240SX Cars & Trucks
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
Nov 15, 2011 | Husqvarna Chain Saw 20" Bar
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Incorrect fuel tank vacuum relief valve
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP canister or fuel tank leaks
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- EVAP control system pressure sensor
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
AC AIR BLOWS BACK AND FORTH FROM DEFROST TO FRONT VENTS
you have a vacuum leak. Check the vacuum reservoir for a leak.
You can spray short bursts of starting fluid on the vacuum lines to find a leak. When engine revs, that's the leak. Be careful.
Vacuum Reservoir Tank and Bracket Removal
  1. NOTE: The A/C vacuum reservoir tank and bracket (19A566) is located either on or beneath the RH front fender splash shield (16102) .
    If the A/C vacuum reservoir tank and bracket is visible from above in the engine compartment, perform Steps 2 through 4. If the A/C vacuum reservoir tank and bracket is not visible in the engine compartment, perform Steps 5 through 8.
  1. Remove the screws and the A/C vacuum reservoir tank and bracket. 1b32ebf.gif
Jun 14, 2009 | 1988 Ford Ranger
My Stihl MS-180be chainsaw is leaking a small amount of gas when full. What could be the problem? Is is the fuel line where it goes into the tank? The saw is working ok?
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Jun 13, 2009 | Garden
Stihl Ms361 Carburettor Logo
110 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
