Question about Microsoft Xbox 360 Console
XBOX 360. No Audio or visual,yet everything else seems okay
When i start up to xbox 360, my Samsung flat screen says "searching for signal" and then turns to "no signal" i have both no audio or visual. I tried using a different A/V cable and still nothing
    Problem Solver:
  • 7 Answers
Are you using and hd cord if so check your plugs make sure you are in the right slots then if hd cords there is a switch on the plug in to the xbox that needs to be switched to the hd setting
Posted on Jun 18, 2009
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
Xbox 360 not sending audio/video signal. Tested on 3 different TVs with both the AV cables and the HDMI cable, no red rings, everything seems to work, just no video or sound.
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Jan 26, 2010 | Microsoft Xbox 360 Console
No Xbox image via HDMI
the only thing i can think of is that you havent flicked the switch on the hdmi cables wher the plug into the xbox from tv to hdmi, if you have the go ahead and get it replaced
Jan 04, 2010 | Microsoft Xbox 360 Elite Console - Black
Wont put out a picture or make sound when turned
turn off your xbox and switch the switch on the video/ audio chord and turn it back on. or just get a new audio/video cord
Nov 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 halo problems
my halo sometimes does the same thing when i start up the game but pressing a usually gets you through it, but if your xbox 360 overheats within minutes and is an older xbox 360 its usually a burnt out fan or just full of dust, if its old then ur warranty might already be out and if it is just open up the xbox and use an air compressor or anything else to get all the dust out of the xbox. in my case everything was just caked with dust. anyways... good luck
-Armand M.
Jul 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 trys to boot up manhunt i get audio but no visual the
Please call 1-800-4MY-XBOX for troubleshooting steps. e
Jun 15, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
No visual!! or Audio!!
it is set to hd swich it to non hd
Sep 13, 2008 | Microsoft Xbox 360 Console
Xbox 360 audio video problem
has it been flashed with xtreme firmware?
check the scart cable and make sure the switch is on the right setting (tv/hd)
when it was working did you put a game in and was you asked to update? if so you could have got a bad update.
if you have a hard drive detach it and then try turning it on.
if none of these work write a reply in this section and i'll get back to you.
please rate my solution and how it helped you
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
