Question about Acer Aspire One D270-1679 Atom N2600 1
I need to update my graphics card - Acer Aspire One D270-1679 Atom N2600 1
I recently bought an Acer 5742G notebook and I keep on getting a pop-up saying my video card is not compatible with Direct3D. Can I update my video card driver? if so, how?
You should be able to update your driver for the graphics card. If you can, open the Nvidia control panel. Then, if you look around in the menu, you should see something along the lines of "Check for new update". Just click that and it should lead you along to update the driver. If you can't find the Nvidia control panel, or for some reason the "Check for update" isn't working, you can go to this link to get updated drivers for Nvidia graphics cards. They even have an auto-detect graphics card feature.
Download Drivers
Dec 18, 2012 | Nvidia GeForce FX 5500 Video Card Graphic...
I downloaded a game and told me that my graphic card needs to be updatedm, how do i update it?
Depending on the exact text of the message, you need to either update the drivers, or you need a newer graphics card. To update the drivers, go to the graphics card manufacturer's website and download/install the latest driver.If the graphics card itself needs to be replaced, you will need to purchase a new graphics card (check the game requirements for the type/make/model card that will work), then install it to your computer. If you already have a graphics card, it's merely a matter of replacing it with the new one and installing the drivers/software that came with it. If it's built in to the motherboard, you will need to install the graphics card, install drivers, then disable the onboard in the bios (check your computer documentation for how to access the bios, typically it will be holding the del key when you see the pc manufacturer's splash screen on boot). If you don't want to get that in depth, most computer stores will do the installation/configuration for you if you purchase the graphics card from them.
Mar 05, 2011 | Computers & Internet
Low fps in wow after driver update
Hello there
After the update this normally happnes for these cards
OK what needs to be done is on the graphics bar the settings this needs to be turned down
Then in the effecs section all of them need to be turned down a little at a time and then test as you are doing this till you get the fps that you are wanting Plus depending on the graphics card you may want to have the g force rad 6500 series or the latest one the gm recommends we have had this problem till we get the new graphics card and our problem went away ok ?
Hope this helps
Best regards mike
Jan 26, 2011 | ATI RADEON X1650 Graphic Card
I have an Acer Aspire T180E. Google Earth will
Perform a Windows update first to see if there is a Microsoft update for the card. If there isn't, then go to the Acer website, look up your computer, and see if there's an update for the card there. Also, download the various "custom" updates like Directx to install in the computer from the Windows update site.
Dec 22, 2010 | Acer AOpen PA (32 MB) Graphic Card
Hello sir I've intel desktop computer. when I play high graphic video, the screen goes blank & dark
HI, Regarding this issue please do update the graphics card driver for your computer.
Nov 19, 2010 | Computers & Internet
In 3-d views, the screen is black unless I am in a mode moving the object. How do I fix this?
Get a better graphic card because your current graphic does not support 3-d view.
Update your present graphic card with the latest drivers updates or patches.
If it does not work you need to replace it with a better graphic card which support 3-d views.
Jul 17, 2010 | Punch Home and Landscape Design Suite for...
How to solve D3DERR not available
Without seeing your system specifications, cpu type, ram, graphics card make and model, etc... I will offer some suggestions:
Update your Direct X drivers, and then update your graphics card drivers, in that order. You may find that completely uninstalling your graphics drivers may be needed before a new install.
You may need to update your video card. If you have an older card, but are trying to play a newer game, even some of the web based flash games like Mercenary Wars, you can get these errors.
Jun 27, 2010 | Intel Computers & Internet
Want to update vga @ utilities of asus graphic card EN8400GS.
You are doing just fine. Go here http://usa.asus.com/product.aspx?P_ID=eZUUjmujLGdZmzmI select the o/s you have. There is no need to download all 3 driver updates, all you need to do is download the latest one. All VGA stands for is Video Graphics Accelerator. That is what a graphics card is called. Feel free yo download any utilities you like, only if you feel you have the technial know how to mess with different settings. I would just suggest the latestVGA update and leave the rest alone. Good luck!!
Mar 14, 2010 | ASUS En8400gs Silent/htp/512m Pci-e, PCI...
Need to update my graphics card
anything modern should be able to handle that resolution. should say on the package what the max reso is and if its over what you need id say its a safe bet. That card your using is really old and out dated. i dont even think you can by cards that have less then 128mb of vram on them anymore.. hope this helps, good luck.
Jan 22, 2008 | Computers & Internet
Acer Aspire One D270-1679 Atom N2600 1 Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
