Question about Garden
C38h cutter won't start
    Problem Solver:
  • 5 Answers
CHECK THE WIRING FROM THE SWITCH TO THE CUTTER CLUTCH IT COULD BE BROKEN OF
Posted on Apr 13, 2014
Simadre plasma cutter blows breakers as soon as you turn it on
WTF is a "tipo" ? YES your machine is defective.
Dec 27, 2013 | Welding Tools
Why does my Cub cadet mower blade stops and not restart?
check for worn belt or tensioner not being tight enough. check for a failed bearing on a cutter spindle.
Jun 16, 2013 | Garden
Mishto plasma cutter won't work
You need to check the power supply, the air pressure switch.
Mar 29, 2013 | Welding Tools
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
I think I ground up a plastic bag in disposal....I have cleared out as best I can, turned the blades with a wrench, re set the button, but it won't move, just humming....does the unit need to be...
Don't keep running the disposal when it is humming or motor will burn up.
You might need a plumber, and/or might need to replace disposal.
1) If the disposal cutter disc turns freely, and motor will not start then disposal has gone bad.
2) If disposal cutter disc is still stuck, then you might be able to salvage by removing two nuts on p-trap below sink.
P-trap drops free.
Remove 2 bolts holding tailpiece to side of disposal so you have access to plastic bag from below the cutter disc.
Keep removing plastic bag and keep working the wrench from below. It should eventually give way.
Put wood broomstick down sink opening and wedge broomstick against sink opening to get cutter disc to rotate.
Spray WD40 into opening to help lubricate the struck parts.
3) I wrote ez disposal replacement steps that also cover tips for reassembling p-trap.
http://www1.fixya.com/support/r7929008-replace_garbage_disposal
Sep 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Would you purchase the 400 hobart or go to 500 hobart plasma they seem to cut the same thickness on the metal chart..
It's all about duration. How much metal do you need to cut continuously. Although the 400 will cut a similar spec it won't hold out as long. So if it;s lots of short cuts the 400 is fine, if you need to cut thicker gauge for longer period go 500.
Aug 16, 2011 | Airforce HOBART AIRFORCE 400 PLASMA CUTTER...
My miller spectrum 701 was set up for 1ph 230 and got plugged into 460 and fire shot out of it several times.what would it take to fix it?
I'm not recommending that you do this, but if you were to open the covers you'd be able to identify visually the blown boards and on the boards are the codes for re-ordering. This is not a guarantee that other boards won't be fault, but they should be ok.
Jun 13, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
