Question about Nissan Vehicle Parts & Accessories
Check engine code p0500 - Nissan Vehicle Parts & Accessories
  • 20 Answers
Vehicle speed sensor.
Posted on Aug 22, 2014
What are some signs that a speed sensori s bad on a 2003 frontier nissan
fault code is p0500
symptoms
loss of anti-lock brakes the "anti-lock" or "brake" warning lamps on the dash may be lit the speedometer or odometer may not work properly (or at all) your vehicle's RPM limiter may be decreased the shifting of an automatic transmission may become erratic other symptoms may also be present
Read more at: https://www.obd-codes.com/p0500
Copyright OBD-Codes.com
if the engine check light is on
the engine computer has fault codes to be read
this is the speed sensor on a 2003 nissan frontier
Oct 14, 2016 | 2003 Nissan Frontier Crew Cab
Have a hard fault code P0500
According to http://repairpal.com/OBD-II-Code-P0500:
Vehicle Speed Sensor Malfunction
Symptoms
  • Check Engine Light will illuminate
  • Vehicle may not shift properly
  • Speedometer may not operate correctly
  • In some cases, there are no adverse conditions noticed by the driver
  • In some cases, there may be performance problems and/or shifting problems.
  • Other warning lights may come on such as the ABS light and Traction Control light.
Common Problems That Trigger the P0500 Code
  • Defective Vehicle Speed Sensor
  • Defective Speedometer
  • Vehicle Speed Sensor wiring or connector
  • Communication (CAN) bus problems
  • Defective transmission or differential Vehicle Speed Sensor drive gear
Common Misdiagnoses
  • Speedomter problem
  • Internal Transmission problem
  • ABS/Traction Control probelm
  • Driveline problem
Mar 27, 2015 | BMW 325i Cars & Trucks
I have a 1996 Nissan 240SX SE, I've been having the check engine light P0500 for a long time, I was told its not my speed sensor since my speedometer works. Also the error code P1445 my EVAP volume pu
P0500 since the speed dometer is working and you get the code P0500 The harness from the speedometer to the ECM need to be check, Go behind the spedometer disconnect and reconnect and retest,if you have a no go go to the ECM disconnect and reconnect and retest ,Your problem is basically in the harness from Speedometer to ECM.As for P1445 make it a hobby of inspecting the canister purge valve hose for rupture or torn if all good replace the purge valve
Nov 11, 2012 | Cars & Trucks
Code p0500 toyota yaris 2006
Error Code: P0500
Fault :
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
1. Wiring harness.
2. Vehicle speed sensor (VSS).
3. Engine control module (ECM).
4. Combination meter.
Apr 24, 2012 | Toyota Yaris Cars & Trucks
Check engine light code P0500 and P1618. What is wrong? 2000 Volvo S40
P0500 Vehicle Speed Sensor A Malfunction P1618 SBDS Interactive Codes Check the wiring going to the transmission. Look for a pinched wire from the car being put on a rack or possibly an accident you may have had recently. If you can find no problems with the wiring or connections then it is time to see a professional transmission expert. It may just be that the transmission has an internal problem.
Sep 09, 2011 | Volvo S40 Cars & Trucks
I have a Suzuki Sx4 2008, the engine light is on and the problem code is P-0500, I just replaced the left-front bearing 2 days ago, and also the ABS light is on, could tell me what the problem is and how I...
P0500 is a problem with the vehicle speed sensor. The ABS light on is also caused by this P0500 code.
Get the vehicle speed sensor checked, see if the wiring is causing the problem (frayed). If there is no problem with wiring, try replacing the vehicle speed sensor.
Aug 12, 2011 | 2008 Suzuki SX4
03 caravan trouble codes P0500 & P1698 drivng car down shifted to 2nd spedo stopped working all ligts on drive selector came on. parked car for 4 hrs restarted and drove normal except for chk eng light...
First take to your locial parts store the will check the meaning of your codes, for free, If no codes come back up you need to reset your ecm " Computer" good luck to you.
Apr 04, 2011 | 2003 Dodge Caravan
The VSC and Check engine light turn on for lexus 1999 the cood is p0500
Toyotas and Lexus cars have some unique feaures. If your fuel cap is loose or the O2 sensors on the exhaust are faulty this results in an emission problem and the engine computer unit (ECU) engages the check engine light and disables the VSC (the VSC light comes on to warn you that it has been disabled). However you have p0500 code which says the car has no speed sensor signal. The seed sensor is located on the side of the final drive from the transmission and its job is to measure the speed of rotation of the output shaft. The ECU will compare the signals from this shaft along with the speed sensors in the wheel hubs. If there is a difference between these signals the VSC is engaged to apply braking effort to which ever wheel is slipping (running faster) than the other or that the transmission speed sensor would warrant.
So you either have an emission fault has fed back to the VSC and speed sensor missing (p0500) condition, or you have a faulty sped sensor which has tripped the VSC light and in turn the CEL.
Check your fuel filler cap is on tight, turn radio off and disconnect the negative lead to the battery for 5 minutes (this should clear the ECU memory of the code error). If p0500 error and CEL and VSC lights come back on then check the electrical connection to the speed sensor. Ensure it is clean and making a good contact, check the wiring for continuity. If everything else looks good consider changing the speed sensor.
Sep 14, 2010 | 1999 Lexus ES 300
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
