Question about Sony Televison & Video
Sony Projection TV Model KP-E41MH11, Need focus and screen control No. 1-223-925-22 or appropriate, fly back transformer, H.STAT 8-598-955-12 parts. kindly help where can i buy this parts
Need spare parts for mode, KP E41MH11, not clear the screen, dull colours are coming, picture cannot seen properly, need help
Slinteriors
  • 8617 Answers
SOURCE: sony kp-53S25 issues please help
The vertical circuit needs to be checked. It could be the vertical output needs to br resolderd or you could possibly have a bad capacitor. if you need more assistance let me know.
Posted on May 22, 2008
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
johnnydiode
  • 647 Answers
SOURCE: hi!! my sony projection tv kp-51ws500 shows double
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Posted on Sep 30, 2009
  • 145 Answers
SOURCE: No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Posted on Nov 10, 2009
ladywinn
  • 5138 Answers
SOURCE: projection tv colours out of focus
First look on back of your TV find Model# and chassis Then POST it again here! In the mean time you have a focus and screen drive control Block On your [Deflection Board the one that has FBT flyback Transfomer it will have 2 wires comin out of it one will fo to control box there will be 3 contros on top R/G/B for focus and 3 controls R/G/B below them for screen drive to each TUBE adjust them.
Posted on Nov 19, 2009
SONY PROJECTION TV Model KP.E41MH11
Probably have to replace both as a unit. Try Ebay if not available through Encompass or Fox.
Apr 13, 2014 | Televison & Video
Please help me
Ok, thanks.
You should do following adjustment if you have enough experience of TV repair.
Please take off front cover of TV and find Focus Control Block, black part with 6 control knobs on it. You need to adjust Screen Volt of Red Green and Blue guns through Screen control knobs on that focus block.
Problem will be resolved.
Mar 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP-57WS500
8 times flash shows error in Flay back Transformer on D Board.
Fly back Transformer part number is ... 1-453-285-41 FBT ASSY, NX-4006
It is available at Part Store on $112.00
All above info are based on your question and feedback.
Good luck.
Sep 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500
The flyback transformer is defective when the LED flashes 8 times. The FBT is located on the main board(D board).
Location of the part is T8005 and the Sony part number is 1-453-285-41
This part is available from this website.
This type of repair might not be a DIY due to the danger of working with devices that generate high voltages.
Sep 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Rear projection tv picture blurry
HELLO sounds like you need to adjust the focus pod on the fly back transformer. not the screens but the focus on the fly back transformer to see if that clears up the picture. hope this helps. "GOOD LUCK"
Aug 09, 2008 | Televison & Video
Blurry Image
Congrats on changing the fly and getting it to come on. If it is a sony as it looks at the top of this page (accurate model?) need only to adjust focus and/or the horizontal static control. can't tell you where the horizontal static control is exactly but there are large wire associated. If not a sony then adjust the focus on the flyback.....top control bottom control is screen or for brighter picture.
Mar 16, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57WV600 screen
I had the same problem except blue lines then all blue..I needed a blue crt tube..........so I'm assuming you will need a green crt tube
Jan 14, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
KP-53S65 blury at times
the screen control and the focus control on the flyback transformer need to be turned down a little
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
