Question about Air Tools & Compressors
I cannot get to the inside of my Ryobi Air Pump to replace the ..
My air pump is a Ryobi P730 18.0V MAX PSI: 150. I have removed the 9 screws that hold it together and I cannot get it to come apart so I can replace the tire inflation hose. What else do I need to do to take it apart?
There is a tenth sdrew under the label on the back that has the model number on it...falls right open then..I am sure they do this so it voids the warranty as I tried very hard but label gets damaged when you peel it off...mine had a leak in the hose internally going to the digital presssure gauge...never flexes so it must be a defective part I wonder how many others have failed this way...will call them for a part tomorrow but I do not hold much hope
Posted on Aug 09, 2009
  • Eugene Cuny
    Eugene Cuny Jul 30, 2017
    Thank you rocketwoman - this is a great site too!
  • Dennis Kelly
    Dennis Kelly Jul 12, 2018
    The question on everybody's mind would be why, why, why.
    Thank you, I was getting ready for hammer time.
I have a Black Max 2600 PSI pressure washer, model BM80913, that gives a surge of pressure, and then pressure drops off. Solution?
Pump needs to be rebuilt or replaced, some of those pumps have a replacement surge valve inside, some do not
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Psi Garden
GASKETS FOR VALVE PLATE WHO IS MFG ?
contact Northern Tool,scroll down the page and you will see parts offered as well as a phone number
FREE SHIPPING NorthStar Air Compressor Pump 2 Stage 3 Cylinder 14 9 CFM 90...
May 04, 2016 | Northstar Air Compressor Pump 569cc, 22.9...
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
Compressors
The pressure regulator on an air compressor is designed to let the pump motor run until the pressure in the tanks reaches their safe level. While you are using the air the pressure drops in the tanks until it reaches the level where the pressure switch turns the motor on again and refills the tanks to their rated level. The pressure where these two things happen is usually with in ten psi above or below the rated levels because few regulators are so precise and are affected by temperature that they turn and off exactly at the rated pressures. If a pressure regulator is damaged or broken it is possible for the tank to either reach unsafe high levels or not turn on when the pressure drops to where it should restart the motor. If you are in doubt, have the regulator checked or replaced as overpressured tanks are very dangerous.
Jun 24, 2012 | Craftsman 150 PSI Air Compressor
My M-1820 air compressor is blowing all the pressure out of the pressure release on the centrifugal unloader when it builds max PSI. When the pump is running there is no leaks but when it stops pumping it...
Without knowing what make compressor you have;
- if it leaks air while the pump is running, replace the unloader valve
- if it leaks air after the pump shuts off, replace the tank check valve
Mar 13, 2012 | Air Tools & Compressors
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
1,034 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
