Question about Miele W2240 Front Load Washer
I have a miele W2240 washing machine that does not discharge fabric conditioner into machine wondered if I had a blockage
  • 16 Answers
SOURCE: Wate rleak Miele premier 300
The conditioner part of the drawer is still blocked. Take the drawer out and turn it over, on the bottom of the drawer you will see what looks like a blanking plug, it's about 1" or so in diameter. Carefully, prise off the plug with a flat blade screwdriver, and you will find lots of sludge blocking the syphon path. Remove syphon and and run hot water through until you can see daylight through the syphon hole where you just removed that blanking plug. Re-fit blanking plug giving it a little tap home. This should sort it.
Posted on Feb 08, 2008
mumma_1
  • 903 Answers
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Posted on Nov 03, 2008
  • 122 Answers
SOURCE: Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Posted on Nov 30, 2008
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
Daniel S
  • 4323 Answers
SOURCE: poor quality wash from miele
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 06, 2011
Testimonial: "Thanks I will try that and the quality of wash is not good, white socks look grey"
Novotronic Premier 520. Why doesn't Comfort Fabric discharge automatically?
Probably dirty tray if never serviced there is a blockage in the tray you can take the tray out and clean it if is clean then motherboard problems or valve fault hope this helps
Mar 06, 2016 | Miele Washing Machines
Poor quality wash from miele w2240 and washing smells stagnant. We use a good washing powder and softener. The machine is 7 years old. Should we buy a new one?
Hi
Daniel
Aug 06, 2011 | Miele W2240 Front Load Washer
My washing machine is leaking
Miele W2240 Front Load Washer leaking This video will show you how to find the leak on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 20, 2011 | Miele W2240 Front Load Washer
Miele w2240 check drain and check inlet lights both flash
There is water at the bottom of the machine. You could tilt the machine forward until the water dumps out and then the lights will go away. The cause of the problem could be the following: 1. There is a hole in the seal. 2. A hole in one of the hoses inside the machine. 3. Too much soap (the most common), the suds come out of the door and enter into the bottom.
Hope this works for you. Please leave a feedback.
Feb 28, 2011 | Miele W2240 Front Load Washer
Miele W2240 will not start to spin
out of balance or brushes on wash motor or if still got water inside blocked pump.
Feb 12, 2010 | Miele W2240 Front Load Washer
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Fabric conditioner not leaving compartment properly on miele washer
hiya
sounds like you have a problem with your cold inlet valve or maybe a blockage in the soap dispenser housing. remove the soap drawer and just give the top of the housing a quick clean. if the problem persists you may have to call a miele engineer out as the machines usually come with a 10 year warranty (check first though)
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 01, 2008 | Miele Washing Machines
The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Jul 28, 2007 | Miele W2240 Front Load Washer
Miele W2240 Front Load Washer Logo
53 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
