Question about Fujitsu LifeBook LH530 Notebook
How to disable fn key fujitsu lifebook lh 530
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
Geekman
  • 32281 Answers
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Posted on Jul 06, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Fujitsu Lifebook...keys have popped off and we
Here's a general tutorial
Posted on Nov 21, 2009
  • 59 Answers
SOURCE: need to reattach the W key on my Fujitsu Lifebook P7230
You may have broken a plastic "hinge", more like a tab or clip. Try taking it off again and examine the underside of the key. If it looks ok, try putting it back on. If a plastic tab/clip is broken on the left side, you should be able to go to a small computer repair shop and get a replacement key for it. That way you don't have to replace the keyboard.
Posted on Jan 04, 2010
SOURCE: Replacement of Fujitsu Lifebook N6420 cooling fan
Note this procedure is specific to the N6420, but may work on other N series Fujitsu notebooks. I generated this solution by a step-by-step process on my N6420.
Procedure for replacing (two) cooling fans on Fujitsu Lifebook N6420. This procedure was required because of fan bearing noise, indicating potential failure of the fan in the future and the noise was very annoying. I performed this procedure after about a year of bearing noise and after not finding any reliable procedure on the web. Fujitsu offered to replace the fans for $230 - far more than the laptop is worth at this point. Below is the correct procedure for the N6420 and specific to that machine.
You will need to purchase two cooling fans Toshiba Part Number S6055AM05. Be sure and purchase the ones with metal backing on one side of the fan. You can find them on eBay for about $10, but beware of what you buy. Recommend you purchase new OEM fans and not refurbished fans as they may not come with the thin metal heat transfer plate provided on the OEM fans. Some of the knock-off and refurbished fans do not include the metal backing, heat transfer shield. You will not need thermal paste.
Note: All of the other instructions on the web I found for the N6420 were incorrect and seemed to be lifted off some other notebook. I actually performed these instructions and made sure they are accurate.
Note: While you wait for the new fans .... and you must use your N6420, but want to buy yourself a little time before the fan(s) totally die ... you can try this procedure at your own risk ... and spray a very small amount of silicone lubricant between the fan electronics and the spindle - this area is easy to indentify if you hold one of the fans on its edge. The use high pressure air spray to blow out any grit, dust and silicone overspray - wipe each fan with a clean cloth. This little bit of lubrication and cleaning made the bearing noise go away. Both fans are spinning up ... but, I ordered new fans anyway to make sure the notebook would have adequate cooling and to preclude the old fans from going bad and causing catastrophic overheating.
Here is the fan R&R procedure itself:
- Shut off the notebook and disconnect all peripherals
- Remove cover to RAM (optional)
- Remove Battery
- Remove HD Cover and HD(s) (I have two - some may only have one)
- Remove 15 retaining screws
- CAREFULLY - Remove base/bottom notebook cover, take care on the side with the PCMCIA slot, USB port and sound ports
- Note orientation of the two fans so you can replace them the same way
- Now remove the two old fans (two screws)
- Install the two new fans
- Replace two screws under HDs
- Replace two screws under battery
- Reinstall the base cover - take care on the side with the PCMCIA slot, USB port and sound ports
- Replace the remaining base cover retaining screws
- Replace HD cover and its retaining screws
- Replace RAM Cover
- Make sure you have no/zero retaining screws left (all 15 screws and the HD cover screw are identical)
- Restart Notebook and get back to business
Posted on May 14, 2012
Testimonial: "I had to log in as my better half to generate this correct procedure. This is the step-by-step procedure for replacing the fans on a Fujitsu N6420. There is no need to take the keyboard out and no requirement for thermal paste. This procedure is far easier than it appears to be and is specific to the N6420."
FUJITSU LIFEBOOK L SERIES LH-530 WINDOWS 7 IS NOT GENUINE
Contact Seller, If got from the Pirate, Phone Him!
Apr 26, 2014 | Computers & Internet
How to screenshot on a fujitsu lifebook
Use PrintScreen key on keyboard, or ALT PrintScreen. Better yet, install PickPick on your computer and use it.
Apr 03, 2013 | Intel S6240 Notebook
Fujitsu Fn key stuck laptop PC Laptops
The Function keys can be usually disabled by a manufacturer provided program, in the control panel.
You can also probably download a replacement from Fujitsu.
Fujitsu America Support
If it is a hardware problem, it should be coming up as a keyboard error on start up, it will not say which key is stuck, so this is probably a software issue.
The manual is listed below for the function key use.
http://solutions.us.fujitsu.com/www/content/pdf/usermanuals/sseries/S7010,S7010D_ONION_USERGUIDE.PDF
Dec 12, 2012 | Fujitsu Siemens LifeBook S7010 Notebook
I have Fujitsu LH 530? but microphone not working. Where I can download drivers&
Try this link:
http://www.laptop-software.com/fujitsu/fujitsu-lifebook-lh530-windows-7-drivers/
Mar 02, 2012 | Computers & Internet
How to mute the microphone?
try using the following keys
Fn key +F9 key
or to be more precise
Fn Key + the jey with a Speaker image on it with an X mark
hope i could be of help
Mar 28, 2011 | Fujitsu LifeBook® E8110 PC Notebook
My bluetooth radio is disabled. How do I enable it? Fujitsu Lifebook E Series
Hi. Check first if the bluetooth driver is installed in the system. You can fo to control panel and click system, then go to device maanger then search the devices under bluetooth. If bluetooth is installed then all you need to do is to press Fn key + F5.
Jul 26, 2010 | Computers & Internet
Touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Oct 19, 2009 | Fujitsu LifeBook A6120 Notebook
Fujitsu LifeBook LH530 Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
