Question about Honeywell Northern Computers NSTAR - Access Control Software Only
NStar NS2 Panel intiliazation Fail
NStar NS2 Panel Intilization FAil
  • satya
    satya Apr 26, 2014
    sir. After loading the software NStar (Updated) in windows 7 the loop connection problem and form Control Map Panel Intilization Fails.
Tip
A trick for modems (dial up)
u can try this tip,
by clicking on,
start > control panel > phone & modem options > Click modem tab, select ur modem and click properties.
Go to advanced tab and in EXTRA INTILIZATION COMMANDS write " at&fx1 " without any quotes.
Click OK and then connect to internet.
U will get a at least 115 kbps speed. ( It depends upon network traffics also but it will help for sure for some extends
on May 24, 2010 | Computers & Internet
All of my access codes have been deactivated. How do I fix it?
Hopefully you have a recent backup of the database. Just restore the backup. I cannot stress enough the importance of making a backup on a regular basis.
Aug 15, 2013 | Honeywell Access Systems NStar Access...
Nstar shut off my power to fix something my washer was on. Now it is not working
Hello iamtubin2 - Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 09, 2012 | Frigidaire ATF6000ES Front Load Washer
Vestel T845 Fail
then replace it if it fail check dalbani.com for parts.good luck.
Sep 13, 2011 | Televison & Video
Vextra VX607 cd/clock radio came with no manual. There is no 800 # or e-mail address or website to download a manual. Cannot figure out how to work some of the things or turn the alarm off for weekends. ...
To turn off the alarm: press Alarm 1 or Alarm 2 button 3 times rapidly until the matching indicator disappears from the display (depending on which alarm you want to deactivate).
Try the following site: http://ns2.xnik.com/owners_manuals_index_by_category.html . Scroll down to the Vextra manuals. The direct link to the PDF is: http://ns2.xnik.com/Owners%20Manuals/Vextra/VX607%20Manual%207-26-07.pdf .
I hope this helps.
Mar 10, 2011 | Audio Players & Recorders
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Pedal inputs messed up? just buzzes, no sound!
Here is the schematic:http://www.godiksennet.com/images/sch/NS2.jpg Try testing or replacing Q1 first.
Nov 25, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Honeywell Northern Computers NSTAR - Access Control Software Only Logo
66 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
