Question about Miele W487 Front Load Washer
Miele drain indicator lamp keeps flashing nearly every other wash nothing in drain
SOURCE: Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
Posted on Mar 14, 2009
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
blueextc3221
  • 15935 Answers
SOURCE: Hi there, my Miele W
Please ensure you have used the proper procedure on page 26 of the manual for cleaning the lint trap.
MANUAL - LINK
Unplug the unit for 20 minutes if turning the Dial back to Start/Finish does not reset the lamp.
Thanks!!
Posted on Aug 03, 2011
  • 389 Answers
SOURCE: how to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Posted on Sep 27, 2012
Miele W1203 washer, buzzer sound with no indicator flash. how can i fix it
It sounds as if there is a leak and water in the pan (bottom of the machine) the front of the machine would have to be removed to check and determine the cause of the leak
Aug 02, 2014 | Miele Washing Machines
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Hi there, my Miele W 1903 Novotronic is not draining nor spinning and the drain indicator light is flashing. I have cleaned the filter and the pump seems to be turning freely. Help, please!
MANUAL - LINK
Thanks!!
Aug 03, 2011 | Miele W1903A Front Load Washer
Miele premier novo, the main wash light flashing
Hi
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Jul 28, 2007 | Miele W2240 Front Load Washer
Miele W487 Front Load Washer Logo
29 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
