Stand by problem in aiwa nsx k880
Complete circuit book of aiwa nsx k880
5 Suggested Answers
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
caroldon
  • 17130 Answers
SOURCE: aiwa nsx nwvt99 donot power up always in stand by mode
This can be due to an error in the output which can protect the circuit and also it can be due to problems within the power section to the bias circuits. In all these cases if the processor trips off after a switch on then the fault needs a probe using a schematic so as to confirm the loss of voltage.
Remove speakers to test and also check in all source modes to confirm if the fault is related to just one source.
Posted on Dec 23, 2011
  • 43031 Answers
SOURCE: hi sir i have aiwa nsx k880 and it is going on
Could be power supply failure
Posted on Apr 11, 2014
Aiwa nsx k880 cirecuit book
elektrotanya.com/aiwa_nsx-k880_parts_sch.pdf/download.html
Apr 11, 2014 | Aiwa Audio Players & Recorders
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
Power indicator open but no function audio,as well as selector my unit is an aiwa nsx k880 stereo
To start with you will have to check on the power supply for the fuses, the fusible resistors on the various sub power section near the main transformer. If OK proceed to see the recitifed DC , the supply to the main controller IC the microprocessor in the front panel. You will need some basic electronics to check for the +5 volt to the mP and confirrm if it is working. replace only if confident or get help. If this section is OK then proceed to the mode selector IC to the output IC. This may require some good technical support to prevent further damage by tampering so please check this out. Good day
Jul 26, 2010 | Audio Players & Recorders
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
59 people viewed this question
 Grubhead
Grubhead
