Question about Garden
Pgt 300 spool cover - Garden
How do I remove spool holder from drive shaft?
Depends on make and model. Most electric strimmers have a removeable cover over the spool. This cover has 2 pressable tabs that releases the cover that then lifts off exposing the spool. Some spolls are clipped into this cover, others sit on the drive shaft from the motor. In both cass the spool should lift off / out. Make a note of the direction that the cutting line is wrapped around the spool so that you can re wrap it correctly with new line. Hope this helps
Sep 15, 2016 | Garden
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Can you adjust the toeing out on the pgt 9000 model
    There is no adjustment. Same problem here. Have to replace rims, bushings and spindle axles. Not cheap
    May 19, 2014 | Craftsman PYT 9000 26 HP 48" Yard Tractor
    How can we change the correction tape? We are unable to get the correction tape off. We can take out the regular ribbon. The wheels for the correction tape won't come off and we can't get below taking...
    1. Use the spacebar or backspace to move the carrier to the center of the platen.
    2. Open the top cover.
    3. remove the cassette ribbon if installed.
    4. Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, lift it up and out.
    5. Pass the new tape through the left guide,behind the ribbon guide. The rough (sticky) side of the tape should face the platen.
    6. Attach the feeder spool to the pin on the left.
    7. Attach the take-up spool to the pin on the right.
    8. Turn the take-up spool counter-clockwise until a small amount of white tape is around it.
    9. Replace the cassette ribbon and close the top cover.
    10. Press (CODE)+(RESET)(Q) to move the carrier to the previous position.
    Dec 15, 2010 | Brother ML-300 Typewriter
    The string on my spool ran out.
    • Turn off the trimmer and remove the battery
    • Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
    • Lift the spool of nylon line out of the hub and clear any broken line and debris
    • In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
    • Pull the line through the hole to maintain tension while placing the
    spool down into the hub with the notched side exposed.
    • Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
    • Snap the spool cover back on.
    Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
    How to wind a pull rope
    Thread the rope into the spool and knot the end, pull a 6 to 8 inch bit of slack from between the spool and the outer cover and let the rope set into the small indentation on the outside of the spool. Rotate the spool with rope attached and sitting in the notch in the opposite direction of recoil until sufficient tension is achieved, pull slack back through feed hole in cover and allow the spool to draw the rope into the spool, now attach the handle.
    the notch in the spool is there to allow you to spin the spool without twisting the rope or having it bind on the cover.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
    Jun 14, 2010 | Honda 25cc 4-cycle Mini Tiller
    Renew pull start cord
    Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
    Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
    I need directions to replace string on black and decker cordless 18v grasshog
    Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
    Otherwise,
    1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
    2. remove spool.
    3. place end of string in small hole in center ring of spool.
    4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
    5. snap string into notch on spool and cut string leaving 6" exposed.
    6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
    7. go cut grass.
    Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
    Shakespeare 2660 coarse fishing reel,cant remove spool cover
    According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
    Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
    Garden Logo
    32 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
