Question about Braun Irons
Service center in dubai
It's not heating
Iron always too hot
Problems with an iron's electronic complements should be dealt with by an authorized service center. It typically is more cost effective to replace rather than repair an iron with internal problems. if none of the dials heat works right. its a problem with the setting switch. good-day !
Jan 17, 2012 | Panasonic NI-R73NR Iron
Lights come on but it don't heat up..
Sounds like a defective thermofuse. Rowenta doesn't encourage anyone to repair their product except their authorized service centers. Parts are not made available. Go to rowenta.com to find the nearest service center and call them.
Nov 07, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
We dropped the iron off the ironing board onto the floor, and now it won't heat up.
We located a Black & Decker Service Center here in our town and will be dropping it off tomorrow.
Dec 06, 2009 | Black & Decker D2030 Iron
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
Steam master Iron (Model 4215/003 ) is not heating with water in
May be the timer and heating element seems to be faulty, And i don't want you to check it.. without proper precautions since its electrical equipment..
Please contact service person near by It takes very less time to service it..
Hope this info helps
Jun 01, 2009 | Sunbeam 4214 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
I would like to send my Rowenta Steam Iron somewhere to have it repaired. The piece you click to activate the steam has ceased to work. Where could I send it? Thanks!
If I were in your shoes, this is exactly what I would do. Please go to this website which gives you the warranty approved service centers:
If it is not under warranty, it would be best to telephone the Ph. # of the service center closest to where you live. I am sure that they would be able, and glad; to "Fix Ya'" (Ha! Ha!) right up with an approved appliance repair business, near your home; especially for one of their Products. Best of LUCK & Have a Great Day!
Jan 14, 2009 | Rowenta DG-980 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
No Steam From Iron
I can tell you the stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.You've to send for servicing at your nearest repair shop or agent.
Rdgs
alan
Jan 10, 2008 | Rowenta Professional DE880 Iron
Irons Logo
Top Braun Irons Experts
Are you a Braun Iron Expert? Answer questions, earn points and help others
