Question about LG KU990 Viewty
Battery dies after NO USE!
I charge it till it says full battery then a couple hours n 4 or so txt's later it dies its just outta warrent..like maybe a month what do i do?
  • littlemissso Jun 18, 2009
    i brought a new battery...in fact i brought 2 new batterys they have the same problem in my phone but work perfectly in my partners phone
    in an LG KU990 "Viewty"
  • 97 Answers
Try to buy a new battery, your battery might have leaked or damaged...
Posted on Jun 18, 2009
  • Joshua Escasinas
    Joshua Escasinas Jun 18, 2009
    What's the model and brand of your phone?...
Ps4 controller not full charging
How old is your controller, maybe your battery is dying. Try opening your controller and replace it.
Jan 09, 2014 | Lands Phones
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
Our car just dies out all of a sudden and it sounds like the car wants to start. Then we boost it for awhile maybe 30 mins to an hour to finally start then it will start good for a couple of days. Then do...
Its dying because the battery is not being charged, and it takes power to run the ignition pak to run motor and electrical systems. I would have the alternator checked out as that seems to be the most obvious problem,only other solution is battery will not take a full charge. usually if the alternator is charging it will supply the power to run the car, but if the battery wont take a charge then it will not have enough power to start the car or run the voltage that the ignition needs to operate. solution is bad battery or bad alternator.
Jan 13, 2011 | 1997 Dodge Neon
BATTERY SHORTS WHEN YOU INSERT BATTERY
If it is new Nano Li-ion technology- try to fully charge battery, they work FULL power until they discharge, so they die instantly, NOT like Nickel batteries go slower till they die, so maybe that is only your first impression that it shorts...
May 06, 2010 | Dewalt 18 Volt Compact Drill Kit
1997 Audi died, lost power acts like bat dead but then starts?
the alternator is not charging and once you run out of battery power car dies when you let it sit battery builds a small charge enough to run short period of time.get charging system checked.
Jan 12, 2010 | Audi A6 Cars & Trucks
Hi, I've had the vu for like seven months and it won't turn on
it means you have a fualty battery what you need to do is get a hold of a at&t store or carrier and get a new battery and that should fix you problem
Nov 04, 2009 | LG Vu CU920 Cellular Phone
How long does it take to charge the battery to a full charge...thanks,judy....on a presario V2000
usually 8 hours is what is suggested when you get a new battery. i like to burn down the power on the battery completely till it turns the unit off, then let charge for 24 hours just to reset the battery correctly.
Jul 19, 2009 | HP Compaq Presario V2000 Notebook
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Battery back up is limited to 1 hour only
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
Jan 16, 2008 | Acer Aspire 3680 Laptop
LG KU990 Viewty Logo
199 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
