Question about CDA WC430 Dishwasher
I have the CW447 integrated dishwasher which won't fill with water
This morning when I went to start a heavy duty washing program the dishwasher beeps when I close the door, doesn't fill with water, then beeps after about 1 minute. When I open the door the first 3 red lights on left hand side of panel - heavy duty, normal wash and light wash are flashing. Could you let me know what the problem is and how to fix it please?
    New Friend:
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Posted on Apr 13, 2014
2 Suggested Answers
  • 1632 Answers
SOURCE: CDA wc370 dishwasher wont start,
Clean latch mecanisim ,,,,Close door fully , with a bang ,,
Posted on May 15, 2012
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
F&P Dishwasher Fault
Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
Refer manual
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Mar 18, 2014 | Fisher and Paykel Dishwashers
Machine will wash on hot only will not on cold or will not fill with cold at all
This is an indication that the solenoid on the cold water valve is bad. Or the cold water valve is plugged. If you can get to the valves, use a meter to check the solenoid OR the power to the solenoid. That will tell you if it is bad. If you dont have a meter, switch the wires from one solenoid to the other and see if it fills
Feb 01, 2013 | Whirlpool Clothes Washer Heavy Duty...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
CDA WC130 integrated dishwasher partly fills with water then pumps out and beeps as if the programme has been completed
Check the sensor of the liquid at the bottom of the dishwasher. Sometimes that is the cause of the fault.
Mar 13, 2012 | Dishwashers
CDA WC430 Dishwasher Logo
154 people viewed this question
Top CDA Dishwashers Experts
David Payne
David Payne
john cordey
john cordey
Are you a CDA Dishwasher Expert? Answer questions, earn points and help others
