Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool ultimate care 2 is filling up then will not spin unless I lift the lid and drop it.
  • 111 Answers
Change the door switch
Posted on Jun 18, 2009
The washer did not drain and won't forward to rinse. After removing all the wet clothes and scooping out the water I set it at rinse and it began to fill but I wasn't able to forward it to spin though it...
Check the lid switch first. It will not drain or spin if the switch is not closed. If the switch is ok check the pump for a foreign object or frozen bearing. If dropping the hose allows water to siphon out the blockage may be a small object.
Eric
Jul 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our ultimate care ii is not working properly. it
the lid switch is broken,open and close the lid if you don't hear a click that's a sure sign the lid switch is broke,try sticking a pen or something in where the switch is you might get it to spin and drain but you gotta change out the lid switch
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care 2 washing machine commercial use. it its making a lot of noise I believe when spinning cycle changes as if the brakes are coming on noise gettting worse other than that...
here is one trick to do. put the timer on spin and pull out the timer knob. open the lid and use a screw driver to actuate the lid switch. then with your other hand hold the agitator until the tub gets to a high spin. once the unit is at a high spin then let go of the agitator. let the unit spin for another minute then lift up you screw driver. it should come to a gradual stop and not a sudden stop. let me konw if that works.
Oct 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wahser not spinning
your lid switch is not engaugeing properly its cracked or loose replace it
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
100 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
