Question about Husqvarna Garden
Honda EP6500 CXS carburettor settings Give setting particulars
2 Suggested Answers
  • 1751 Answers
SOURCE: How to set the linkages and adjust a carburettor
Turn the engine off, Put the throttle
lever to the HIGH position. Loosen the
pinch bolt nut on the governor arm a
turn or two; just enough that the arm will
move on its shaft.
With one hand, move the governor
arm so that the throttle plate of the
carburettor is wide open. With your other
hand, use smallish pliers that's
why there is a flat on the shaft to turn
the shaft in the same direction. Hold
everything in that position and tighten
the pinch bolt.
You've just taken all the slack out of the governor linkage.
Recheck the choke, idle and maximum RPM
and you've done all the adjusting
you can do.
Posted on Nov 25, 2010
Clean carburettor Honda generator e-300
Remove it and soak it in "Sea Foam" carbureator cleaner. Should just be 2 screws holding it on. Get the service manual from Honda. Honda com Official Site of American Honda Motor Co Inc
Oct 02, 2014 | Honda Electrical Supplies
I have a Honda 93 XR650L motorcycle. I can't get it to run. It will start for a second and then die. I have put a new regulator rectifier and i don't know where to go from here. I do know that when i try...
start with the most simple things first. fuel filter blocked? carburettor getting enough fuel or not enough? does it puff out any black smoke when starting for that second, will give indication of over fuelling if not.. try manually putting a little petrol into the carburettor might not be getting enough gas?
Jul 21, 2014 | Keihin 1993-2007 Honda XR650L FCR41...
Good morning I have a 1985 honda 1200 interstate my problem is when taking off in 1st gear my clutch is all the way out to the end which means take off is fast cannot take off slow needs lots of gas to...
Hello, do not touch the carburettors they are fine, i am not familiar with the set up on the Honda but from your description its the clutches, i presume it has hydraulic clutch set up since you mention bleeding it, if you have a nice solid feel on the clutch lever than it should be ok but it will not do any harm to give it a quick bleed, hydraulic clutch set ups usually do not have any adjustments but if you can give the lever some free play (only if its adjustable) than it will get you out of trouble, you will need your clutches replaced if you cannot adjust it and there is no air in the system.
Mar 28, 2011 | 1987 Honda GL 1200 Aspencade Gold Wing
How to set the linkages and adjust a carburettor on a Honda HRU 195 mower
move on its shaft.
the pinch bolt.
you can do.
Nov 25, 2010 | Honda Garden
Carburettor float level setting
Usually if the float is adjustable you will set it so if there is a flat surface on top or side of the float it will be parallel with the bottom surface of the carb body when the needle valve just closes (before depressing the spring in the needle)
Jordan
Oct 03, 2009 | 1982 Honda VF 750 S
Petrol is flowing out of the pipe at the bottom of the carburettor... its a honda 300 big red farm quad...
The float is apparently not regulating the needle valve. need to disassemble and clean the needle and seat and set float level
Jun 24, 2009 | 1999 Honda CBR 600 F(4)X
How to replace choke cable on a standard 2003 honda CB 250. particularly at the carburettor end of the cable
depends on if choke piston is moving free an not seized if stuck need to remove carb an soak it with no plastic or rubber parts in carb cleaner630c2ab.gif
Apr 17, 2009 | 2003 Honda CB 250 Nighthawk
Garden Logo
11 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
