Konica minolta 7145
Problambs in konica minolta 514 show on display coping in prograss
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
jqsababa967
  • 145 Answers
SOURCE: Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Posted on Nov 01, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
Konica 7145 say PM fixing unit (Web) won't copy but will print
have tech come out and replace the web roller above the fuser unit, and clear the counter after install. THAT IS LEGACY MACHINE google for the web roller
Jan 10, 2017 | Konica Minolta Konica 7145 Minolta Bizhub...
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
I want to install printer driver of the konica minolta 7145, but i hav no driver cd, then how i can download, anyone can tell me any website.
Konica Minolta 7145 Drivers
From the above link from Konica Official Support you can download the drivers accodding to the Operating System you have on your PC. (Drivers for Windows XP, 2003 & MAC are available)
Hope it helps! Good Luck!
CreativeTECHNOLOGIES
Apr 27, 2011 | Computers & Internet
Konica 7145 Legacy Print Driver
konicaminoltaus.com has a complete list of the drivers for download on the site
Oct 09, 2009 | Konica Minolta Office Equipment & Supplies
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
KONICA 7145 PRINT DRIVER
The Konica Minolta 7145 have two different companies that made the print controller. If you have an older KM 7145 then you need the old Peerless Legacy driver. It's not on KonicaMinolta's website. You can use HP 5Si driver, but you won't have and of the options (ie finisher, fax, lcc).
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
