Question about Lands Phones
Change tone to pulse mode for beetel phone - Lands Phones
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Posted on Dec 22, 2007
  • 3 Answers
SOURCE: pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
SOURCE: changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Posted on Jan 06, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
SOURCE: Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
Posted on Aug 08, 2009
How to change Beetel M71 from pulse to tone dialing
I'm using Beetel M71 model phone but couldn't find program button on my phone. Could you please let me know how to change pulse to tone on this model.
May 10, 2012 | Lands Phones
How to change dialing mode (pulse - Tone mode) in beetel land line
Remove battery and line cable then connect after 30sec
Feb 08, 2012 | Lands Phones
Changing to pulse
Enter SetUp. Look for Global setup. You have the options Area code, Dial Mode. This last option is the one that allows you to change between Pulse and Tone dialing.
Dec 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
Mar 16, 2008 | Lands Phones
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Sep 19, 2007 | NorStar Polycom Soundstation ( Phone...
Lands Phones Logo
18 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
