Question about Konica Minolta Konica 7145 Minolta Bizhub Printer/fax/copier/network Scanner/stapler
Konica 7145 eror show 514
  • Konica Minolta Master
  • 6,680 Answers
Fuser code hot part replace it
Posted on Jan 10, 2016
4 Suggested Answers
  • 158 Answers
SOURCE: Konica 7145 Legacy Print Driver
konicaminoltaus.com has a complete list of the drivers for download on the site
Posted on Oct 15, 2009
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
saxmansaxman
  • 177 Answers
SOURCE: my konica minolta bizhub 7145
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Posted on Mar 13, 2011
Dawlance split air conditioner shows the eror in display f6
Check the condensor fan motor. If less RPM replace capacitor. still continues, replace f.motor.
Aug 25, 2012 | Dometic Heating & Cooling
My 3120 show the eror "check info services" and
wat do u do b'coz of it shows ''check info services''?
Oct 27, 2011 | Nokia 3120 Cellular Phone
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
I use a dl 514 router. the computer shows a wireless connection and a strong signal but i'm not able to get online. now that I'm using a cable, it still shows a wireless connection with a strong signal.
Its quite likely that the router is not connected to your computer wirelessly. Which means, your wireless card is not picking up a IP address. I would suggest two thigns 1. In your wireless utlity , try to repair the connection. 2. Check if you have a static IP address. If you do, remove it.
Hope this helps
Thanks Ranjit
Sep 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Reset dlink 614+ router, forgot password
I don't know for the 614 as there isn't a model like that... Your picture shows a DI-514. Here is the process for that model.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
If you truly have a 614, can you post more about the model number? It's usually written on the bottom of the router.
Aug 30, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
My DVD Player Coby 514 Only Show Load disc
Checa si el laser envia buena luz,limpia el lente del laser puede que este sucio con un cotonete impregnado en alcohol limpialo despues le secas.
Jun 21, 2008 | Coby DVD-514 DVD Player
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
Konica Minolta Konica 7145 Minolta Bizhub Printer/fax/copier/network Scanner/stapler Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
