Question about Euro-Pro EP93 Steam Vacuum
Steam coming from under my EP 93
Thus happened after changing out hose
I have a Euro Pro model #EP-901 steam cleaner I need the manual for
Could not find it listed under Euro Pro, it may be the same as a Shark model as they are the same company.
Does this look like the same model, but different color?
http://preview.tinyurl.com/SHARK-3901-steam-mop
If so the customer support number is near the top of the page on the right side.
Nov 13, 2013 | Euro-Pro EP901 Vacuum
Register model ep/750
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Dec 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I pumped my steam mop to get started as I always do. I heard a loud pop and now it won't produce steam and leaks water on the floor.
The mop broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jun 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam leaking from screw cap. can i get a new one?
you dont need a new steam cap if steam is coming out of the top, that is supposed to happen when the hose is clogged, it would be very dangerous if that didnt happen, the amount of pressure that thing holds is unreal if you think your cap is leakin steam take a second look. if the cap is not physically damaged then it should be working fine, 9 times out of 10 your hose is clogged
Oct 27, 2009 | Tristar SB Steam Buggy Vacuum
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Steam escapes Steam Buggy
I've faithfully used by little yellow Steam Buggy to clean tight corners in my replacement windows and was always to get them looking new again and many other small places that needed blown out with steam when wiping or even scrubbing with a toothbrush doesn't work. I started to use it today and the steam started to come out around the black cap. After searching for a solution on the net I was very disappointed to find everyone else was having the same problem with no real solution. I had my hubby look at it and he said the gasket was worn and slip an o-ring on top of the gasket and now it back to working fine.
Just wanted to pass it along. A 10cent O ring will fix it.
May 12, 2008 | Tristar SB Steam Buggy Vacuum
This is a EURO-PRO X Shark Steamer Model S3325, there doesn't seem to be any power in plugged in, no lights on the handle. Bad switch or is there a fuse?
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
Mar 28, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Polti Vaporette 2400
Not sure this is the solution as my steam/water was coming out from the front.  Although it didn't look like it initially, it turned out to be coming from the hose.  There's a little o-ring that fits on a spike in the hose attachment and that was split.  I replaced it and it's working fine again.  I got my o-ring (in a pack of 200 assorted sizes) from eBay for about £3 but that was only because I was too lazy to go down to my local plumbing/bathroom shop which probably would have sold me 1 for a few pence.  Much better than £50 to replace the hose!
Feb 07, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Euro-Pro EP93 Steam Vacuum Logo
32 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
