Question about Sharp Televison & Video
When my sharp lc 32sb220u is turned on, my direct tv remote will not change channels. this just started. Nothig was changed. after this, i did change the direct tv box and it still would not change channels with the tv on. I can disconnet all cables to the box and have it it plugged in a different outlen in the room and it will not change channels with the tv on.
    Top Expert:
  • Sharp Master
  • 12,962 Answers
That remote has to work / it is a direct tv issue since it is their equipment that you are renting and it is supposed to work with your set..
Did you make sure that the batteries in the remote are good? that the remote unit itself is good ( Use digital camera or am radio to test out - see google)
Posted on Sep 20, 2017
premtech
  • 934 Answers
SOURCE: Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Posted on Nov 25, 2007
SOURCE: sharp television without remote
should be able to go through on the tv unit itself to auto search the channels, i've done in numerous times for friends in dorms who lose their remotes or don't know how to reprogram for the new cable channels. it should be on the tv by the channels and volume buttons.
Posted on Jan 31, 2008
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
SOURCE: Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Posted on Aug 11, 2009
  • 102 Answers
SOURCE: Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Posted on Sep 20, 2009
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
Why am I not able to change channel on Sharp Aquos television?
Try changing channels with the button on the TV to make sure the remote is not bad. Sometimes one or just a few buttons on the remote will quit functioning. It is usually the ones that are used the most. What channel is the TV on? If it is 3 or 4 or one of the aux inputs; it may have been told to stay that way because the channels were changed by a cable box. Go to set up and scan channels into memory. After it has started, do not stop it until it says on the screen that is finished. If you stoop it before it has completed the scan, the TV will keep its original program. (one channel)
Aug 30, 2014 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-32SH130K always goes back to same Channel
go to the menu option and restart your TV settings to the factory settings. If you event can not use the menu and same thing happens, there is something wrong with the remote; maybe a button is being pressed all the time or there is some conductive material stick to the electric board.
Feb 04, 2014 | Sharp LC-32SB21U 32 in. LCD TV
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
I cannot change the channels on my direct TV receiver when tv is
Have you tried a factory reset on the TV.Also try unplugging the tv wait about 20 seconds and then plug it back in.Last check the trouble shooting in the tv manual
Feb 08, 2018 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
