Question about Miele WT 2780 Front Load Washer
Fault code 55 - Miele WT 2780 Front Load Washer
What does codes 54 and 55 mean on my 2001 freightliner columbia 60 series detroit
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
May 19, 2015 | Cars & Trucks
Fault 23-55
A 2000 model vehicle should have 3 or 4 digit codes such as P0023.
Is that what you are looking at ?
Jan 23, 2014 | 2000 Dodge Grand Caravan
92 dodge shadow trouble code 355
Are you sure it's not 1355? The fault codes using the key on/off sequence are two digit codes, and code 55 means the end of the list. So it may be 13, 55. Code 13 means the ECU is not receiving a MAP (manifold absolute pressure) signal. See the link for the breakdown of Chrysler fault codes (bottom of page).
Troubleshooting Fault Codes Chrysler Two Digit Computer Codes 1980s 1990s
Aug 06, 2017 | Cars & Trucks
My 95 eclipse is throwing codes 12, 31, 43, and 55 what do these codes mean?
12-cam shaft position Timing over retarded
31- HO2S heater Control Circuit Low (Needs a new O2 Sensor is what this is telling you)
43- HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
55- HO2S Heater Resistance (Bank 1, Sensor 3)
All of those assume they are supposed to be preceded by a P00
If you are getting ODBI codes these are teh definitions you are looking for:
Code 12 Air flow sensor fault
Code 31 Knock sensor fault
Code 43 EGR fault
Code 55 AV valve position sensor
These may make more sense with that year model.
Jul 22, 2011 | 1995 Mitsubishi Eclipse
Check engine code 55 jeep grand cherokee laredo v6 1997. transmission wont shift properly also pulling code 21 and i figured out that one is for the throtle position sensor
These are the fault codes for your Jeep below;
Jeep
11 IGN reference signal.
13 Fault in the map sensor pneumatic circuit.
14 Fault in the map sensor electrical circuit.
15 Fault in the vehicle speed sensor circuit.
17 Engine running too cool.
21 Problem in the oxygen feedback circuit.
22 Fault in the coolant temperature sensor circuit.
23 Air temperature sensor.
24 Fault in the throttle position sensor circuit.
25 Fault in the IAC motor drive circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
33 Fault in air conditioning cutout relay circuit.
34 S/C solenoid circuits.
35 Fault in fan relay circuit.
41 Fault in the charging system or no field current.
42 Fault in the ASD relay driver circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
46 Battery voltage is too high.
47 Battery voltage is too low.
51 Lean condition is indicated.
52 Rich condition is indicated.
53 Internal problem in module.
54 Fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
76 Fuel pump resistor by-pass relay circuit
Mar 08, 2011 | 1997 Jeep Grand Cherokee
I have 4 codes, 12, 32, 41, 55 If you can help I do thank you.
12 memory to controller has been cleared within 50-100 engine starts
This is not a fault code.
32 egr control solenoid circuit, open or short detected
41 charging system circuit not responding to control signal
55 end of message (test complete)
Jan 26, 2011 | 1995 Dodge Caravan
Jeep Grand Cherokee 1997. Getting check engine light signal 12 14 43 55. Car symptoms are stalling rough idle.
Code 12 = Recently disconnected battery
Code 14 = Coolant sensor high resistance or shorted
Code 43 = Knock sensor or Electronic spark control circuit fault
Code 55 End read code.
Hope helps (remember rated this).
Jun 12, 2010 | 1997 Jeep Cherokee
What do fault codes 12, 21, and 55 mean on a 1996 dodge caravan?
Code 12 = unplug battery recently (allways appear this code)
Code 21 = O2 sensor (the way to solve is replace it)
Code 55 = finish test
Good luck (remember comment and rated this post).
Apr 21, 2010 | 1996 Dodge Caravan
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
Need to know what trouble code 55 is on the 1993 jeep cherokee country 4.0 l
code 55 is the "end" code showing that the diagnostics have been completed. If you had no other codes, then there is nothing stored as a fault in the computer.
Oct 21, 2009 | 1993 Jeep Cherokee Country
Miele WT 2780 Front Load Washer Logo
205 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
