Question about Casio Exilim EX-Z100 Digital Camera
The same problem.... shutting down all the time
Battery charged, shut down while i was taking a pic... lens is still open, everytime i try to turn it on the little light on top is on for a second, but nothing else happens...
  • katta86 Jun 18, 2009
    already did... as i said... battery is charged :( normally, when the camera says that the battery is low it shuts himself down, but then the lens is not open...
    Sergeant:
  • 321 Answers
Change the batt.
Posted on Jun 18, 2009
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
Hi I have a question I have a power shot SX160IS Digital Canon Camera. everytime I'm taking a picture with my camera it's saying charging the lens and it take 1 minute everytime I want to...
iT DOES NOT CHARGE THE LENS. iT IS PROBABLY CHARGING THE FLASH THAT IS CAUSING THE DELAY. tRY IT WITH THE FLASH TURNED OFF MANUALLY AND SEE IF IT WORKS, iF SO, GOOD INDICATION THE BATTERY IS WEAK, NOT HOLDING AN STRONG CHARGE AND NEEDS REPLACEMENT.
Jan 29, 2015 | Canon Cameras
P100 was working took 1 picture and froze open. white screen won't charge
Perhaps you have an empty battery?
Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it.
Switching of a camera causes it to start again, like a cold boot from a computer.
Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
May 05, 2014 | Nikon Coolpix 4600 Digital Camera
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Nov 09, 2009 | Kodak EasyShare M1033 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Casio exilim lens retracts wen u press to take pic
The battery probably needs charging. The camera will automatically shut down if the battery is going flat.
With the Exilim you need to make sure that you don't overcharge the battery by leaving it permanently docked in it's little docking station - this can damage the battery. There is an LED on the docking station which shows the status of the battery. Red is charging, green is fully charged - take it off the docking station.
Dec 11, 2008 | Casio Exilim EX-Z77 Digital Camera
Error Message
Have you tried resetting your camera? To reset your camera, open the battery cover and you should see a small hole inbetween the SD card slot and the battery release switch. Then use a small narrow object (i.e. mechanical pencil with its lead extended) and press into the hole. You should feel it "click" and then hold it for about 3 seconds. Try restarting your camera.
Note: Please backup all the data on your SD card before doing this.
Hope this helps
Aug 14, 2008 | HP Photosmart R727 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Casio Exilim EX-Z100 Digital Camera Logo
99 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
