Question about Voyetra Turtle Beach Record Producer Deluxe for PC
Bought this "GREAT PRODUCT" to record my songs with and I can never remember how to set things up whenever I need my PA system elsewhere. (My sound system also moonlights as my PA- it's a Fender Passport PA) So I have screwed around for hours again changing settings on the computer and such and still it will not record again. Would you guys have a diagram of how it should all be hooked up and what the settings on my computer should be- can't even get the Windows Sound recorder to work now- so I've really balled it up again. I have a Sound Blaster X-Fi sound card in the computer and once upon a time I could record OK. Another issue is that in playing the first track back to try and record my next- the first "bleeds" over to the second so that both instruments are heard on the track??!! Whats up with that?
  • keithathome Jun 18, 2009
    What about all the connections? I think this is a large contributor to the problem.
  • 483 Answers
I had the similar problem on my friends machine, we did a clean uninstall & reinstall of the entire thing.. Worked !
Else try contacting 'em for free & get some stats arount the package from :
http://www.dj-equipment-supplies.com/voyetra/recordproducerdeluxe.htm
Thanks
Fame !
Posted on Jun 18, 2009
    President:
  • 1,383 Answers
First if yout windows sound recoreder is not work then your drivers problem there.
First uninstall old drivers then install again.
Sound goes on and off while watching programmes every so often
This sounds like you have the device on a wrong sound setting. Check the sound settings. For example Dolby sound needs special settings.
Jan 13, 2016 | Panasonic 5.1 DVD Home Cinema System 1000W...
Recorded album and first track is cut at beginning everytime
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Mar 15, 2014 | Sony Sound Forge Audio Studio 9
I got a pre-amp (Focusrite Platinum Trakmaster Pro) with phantom +48v. i got an M-Audiophile 2496 installed to the comp. and a mic Rode nt1A. Eveything is plugged in and installed and iv'e...
the process of elimation will help you to solve your issue. first plug the rode nt1 (great mic by the way), into a good pa head or something you know works, of course you will need to have a pa that gives you phantom power. if the mic works then move on to the preamp. try it in the pa too, if it works move on to the m-audiophle and plug a line level signal into it (a cd player or mp3 player for instance) it this works then you have determined that everything works and you don't actully have a problem other than switching, Also try plugging your mic into the M-audiophle directly and see if thaat works ( don't know if that provides the 48 volts, if it doesn't than you will have to get a phantom supply to plug into first. good luck
Mar 17, 2011 | Rode NT1A Professional Microphone
I have the Simmons SD7PK. It sounds as though the speakers to my amp or through our PA system are busted. What could be causing this?
First thing is to verify your sound system is OK by running program material such as a CD at normal levels through it. If it is OK then you need to consider if your drum set is overdriving your sound system. Drums generate high pulses and can easily saturate PA systems. First thing here is to connect headphones to your drum set and listen how the set sounds via headphones. If both these tests pass muster, then your PA system may be too small to handle the drum audio. In that case, get at least a 15 inch powered monitor, preferably bi-amped to run the drums through.
Mar 07, 2011 | Simmons SD7PK Electronic Drum Set
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at http://audio.manualsonline.com/mdownloads/bd4c0d62-6f82-4bfb-bf83-8d832f3fe222.pdf. Hope that helps!
Mar 05, 2011 | Computers & Internet
Whenever i press play, my MP3 player doesn;t play ANY song!!!!
I had the same problem, and I was ready to take the player back. I was searching under media help and found the help I needed. This is what you need to do: open your media player. Along the top it will read Now playing, Library, Rip, Burn and then SYNC. Sync is what you need to click on. In the area that you would drag music to for a playlist will now have ' Connect A Device'. The rest should be easy to follow. Good Luck!
Apr 02, 2009 | Jensen SMP-115 MP3 Player
Drum set
I USE THE INTERNAL DRUM MACHINE ALL THE TIME, BUT ONLY ONE TRACK AT A TIME PER SONG. I CAN CUSTOMIZE THE SONG BY CHANGING THE TEMPO, STYLE, AND LENGTH. EACH SONG SOUND GREAT. TRY IT. (DAYSHIFT).
Jan 31, 2009 | Tascam 2488 Portastudio Multitrack...
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
I have just had some ipod speakers bought for me (Doss DS-367) and at first they were fine. then i used the attatchment to make an ipod nano fit better and now at the beginning of each song the speakers...
do you have dirty contacts. i dont know this dock but i am working on old hand stuff here. remember speakers with sockets, then they changed to screws, with a socket you get a build up on the contacts. its called decay, oxidization is another word. that is why some things use gold contacts, great if the item you are fitting is gold as well. usless with a standard contact.
you got an adaptor, take it out and fit it about 10 times. then try it.
also, does the main contact point upwards. remember dust falls. put a cover, a hanky or tissue over the contacts to stop dust.
i dont have one of these but remember, i have used pa equipment and the rubbing of contacts really helps.
Oct 28, 2008 | Audio Players & Recorders
Humming sound
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
May 15, 2017 | Bose Lifestyle 12 System
Voyetra Turtle Beach Record Producer Deluxe for PC Logo
104 people viewed this question
Top Voyetra Turtle Beach Computers & Internet Experts
john smith
Alun Cox
David Payne
David Payne
Are you a Voyetra Turtle Beach Computer and Internet Expert? Answer questions, earn points and help others
