Question about Nintendo Wii Video Game Consoles & Games
We have been playing wii for months just fine. now wii will not turn off and shows "no signal" i have to unplug it to turn it off. i tried AC adapter trick i even swapped it out with a different one
Tv can do an HDMI cable which I don't have for Wii . Just the five plug ........kids also leave Wii on which I fear is perhaps a factor.
    Filmmaker:
    Uploaded 5 video answers.
  • 55 Answers
You can press and hold the power button on the Wii for 10 seconds, and if that does not fix it, try and open up the console and reset the system. Here is a video to help you take it apart:
Thanks, Yomanwazzap
Posted on Apr 20, 2014
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
ionfreek458
  • 52 Answers
SOURCE: Wii Console signal
you should make sure that the cords are plugged in correctly in both the wii and the tv. if not, you should try different cords and a different tv.
Posted on Oct 17, 2008
fsdf445
  • 28 Answers
SOURCE: Wii - Just stopped Working.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
127
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: Power light is green but nothing on the screen
Check the AV cables may be not connected right or the AV cable is broken.
Posted on Mar 27, 2009
sdff
  • 26 Answers
SOURCE: Wii won't power on
2022
Posted on Apr 03, 2009
My wii is not working, we turned it off one day and it did not turn back on when we went to play it. Now the light won't come on and everything is pluged in.
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
      2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
      3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
      4. While you're waiting, check the AC Adapter for the following:
        • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensedproducts are not fully compatible and may not work correctly.
        • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Jan 01, 2011 | Nintendo Wii Console
Can't turn on the Wii. It goes on for a second and turns off, we've only had it for three months. I tried unplugging the Wii AC Adapter from both ends, waiting ten minutes and plugging it back in...same...
Try another wall outlet, and if possible try another AC Adapter. If the same thing happens then you know for sure its a problem with the Wii. If its under warranty, bring it back to the store and get a replacement. If its not under warranty then you'll need to get a new one.
Apr 22, 2010 | Nintendo Wii Console
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
Wii won't display anything and no sound
check if all the chords are plugged in. if they are try blowing on them.
Dec 20, 2009 | Nintendo Wii Console
After not using my wii for about a month i went to play it the other day and it wouldn't turn on. The indicator light on the power button is off, not green, red, or orange. All the cords are connected, I...
Unplug it from the wall outlet (NOT from the Wii). Leave it unplugged for a good 5 to 10 minutes. The AC adapter needs to be reset (more on that below).
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 03, 2009 | Nintendo Wii Console
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 15, 2009 | Nintendo Wii Console
Wii Console signal
Oct 15, 2008 | Nintendo Wii Console
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
Wii will do everything but it won't play games.....
I had the same problem. No new games would play but the old games played fine. I clicked on the spinning disc icon (where the game should come up) and it prompted me to do an update. I accepted. Once the update was complete (took about a minute or 2) the new games worked fine.
Jan 11, 2008 | Nintendo Wii Console
My Wii Keeps showing "An Error Has Occured".
10 hours!? wow, hard gamer.
This amount of playing nonstop is dangerous, and causes it to overheat. Leave it unplugged for 24 hours, maybe put it under a fan.
Then try, if your still getting an error, it may be fryed.
Dec 30, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
