Question about Candy Washing Machines
Keeps flashing stain blaster and doesn't continue washing
KevinWhite
  • 1902 Answers
SOURCE: my candy alise washer dryer
Hello & Welcome to FixYa
The problem is with the door lock-switch assembly not working, the unit detects that the door is not closed/locked and so will stop in middle of cycle. Please get back to me if you have any other questions.
Kevin
Posted on Jan 09, 2011
Daniel S
  • 4323 Answers
SOURCE: HOOVER NEXTRA Although this machine is
Hi
The issue seems to be with bad door lock-latch assembly and should be replaced. You can try to clean the latch mechanism and also blow air with help of hair dryer to see if it works....if it won't work then it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: Candy Alise-the stain blaster and
Hi again,
11 flashes decodes as 'faulty dryer module or wiring to it'. Not sure that helps you other than saying that a service call is required, sorry ;-0(
Good luck,
John C
Posted on Mar 23, 2011
  • 6277 Answers
SOURCE: Model no. GO W464-80 S/No. 3/002993
Hi from retired Englishman in SW France
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 18, 2011
  • 6277 Answers
SOURCE: the stain remover button extra rinse button wont
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
John C
Posted on Sep 25, 2011
I have a candy alise gow475, it starts up a cycle but stops whenever the drum should start to turn
motor speed sensor problem u cant fix yourself .it needs a skilled technitian.
Mar 30, 2015 | Candy Washing Machines
My machine is stuck on stain blaster mode and i dont know how to remove it to continue cycle to spin clothes
sorry but without make and model we have no idea what machine you even have
Mar 29, 2015 | Washing Machines
Bottom of bowl is stained very much. Appears to be a defect in the the finish?
Try using one of these A product called Kaboom Bowel Blaster and let it sit in the bowl for a while, then brush clean. This worked for me when others failed. You can try muriatic acid as a toilet bowl cleaner.Again let it sit for a while then brush and flush available from places like Home depot.Sometimes the toilets are not glazed as well as they should be you might call it a defect I call it poor quality control.
Aug 01, 2014 | American Standard Home
Grease like stains on clothing after washing
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
Jul 30, 2013 | LG WM2301HW Front Load Washer
"Clean" light keeps flashing. Machine doesn't
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Candy Alise-the stain blaster and 90 degree lights are flashing and it will not function. Please help!
Hi again,
Good luck,
John C
Mar 22, 2011 | Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Washing Machines Logo
14 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
