Question about Honda Horizontal OHV Engine 270cc, GX Series, 1in. x 3 31/64in
Engine will not start
The engine was hunting under load. So I decided to clean the air filter and the main jet on the carburetor. The engine will not run at all now. It may run for about 5 seconds, backfires and cuts out. I have since removed the carburetor and cleaned everything with Carburetor cleaner but I still can't get the engine to run.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 97 Answers
Spray some either into the air filter. If it starts and runs for a few seconds then it is not getting fuel. If it won't start it may be getting too much fuel. Verify that there are no vacuum leaks and that the bowl of the carb has gas in it.
Posted on May 16, 2014
2 Suggested Answers
  • 104 Answers
SOURCE: I want to clean the carburetor on my air
WHY do you want to clean the carb? If you have no problem, leave it alone. If you are concerned about old fuel in it, there is a bowl on bottom of the carb about 2" in Doameter. There is a bolt in the middle of the bowl that retains it. ( 10mm as I recall) remove the bolt and bowel. Clean out the bowl with a little mineral spirits or solvet and reassemble.
Note, turn off the fuel from the fuel tank before removin g the bowl
good luck
Posted on Mar 17, 2009
Took the airbox out my hyosung rx 125 and fitted a pollini air filter starts and drives but when I hit 35-45mph it starts sort of sputtering tried adjusting rev screw but nothing still does the same??
Hi, Ricky if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Closed to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have nice a day.
How to remove welch plug air fuel screw cap from any motorcycle or small...
Carburator Theory and Tuning
Life On 2 Wheels
HYOSUNG RX 125 Service Manual
HYOSUNG RX 125 Parts Catalog
https://www.alpha-sports.com/Parts/H_RX125.htm
http://mybikemanuals.com/hyosung/hyosung-uncategorized-owners-manuals
Apr 12, 2017 | 2002 Hyosung RX 125
Why does my Ryobi 2200 watt generator surge at low RPM's
The engine is not getting enough fuel. Try choking it some and see if this helps. If it does, then check the fuel filters. If you still have problems, then you will need to clean the carburetor or open the main jet if it is adjustable. Modern small engines are se to run as lean as possible to keep pollution down. This is much worse on small engines shipped to California. If the carburetor and filter are clean and you still have the problem, take the carburetor to lawn mower shop and see if they will replace the main jet with one a little larger.
Let me know if this gets you going. Robert
Nov 17, 2014 | Electrical Supplies
Bike won't run smooth.
Hi, Joe if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carburetor Set up 101
KTM 250 SX 2005 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 250 XC Owner Manual
May 19, 2017 | 2005 KTM 250 EXC
Yamaha xt600e flats during acceleration with new k&n air filter what should i do?
Hi, Steiner if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
Poor acceleration after replacing air filter
New to MCN Suzuki Bandit GSF600S Advice
Yamaha XT 600 AC Service Manual
OEM parts for Yamaha
http://www.dualsportafrica.com/Yamaha%20XT500E%20and%20XT600E%20Manual.pdf
Jun 13, 2014 | 1991 Yamaha XT 600 E
Jetting on 1994 yz 250. the main jet is a 330 the pilot is a 40 and the needle is a 61. we mix the oil to 50:1 but it loads up onan idle and in the middle. we are at 5000' elevation.
Hi, Anonymous it should be noted that your performance issues are not electrical ie. faulty charging system, battery condition, and connections etc. If your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
Two stroke Carburetor jetting How to performance tune your two stroke carb...
YZ250 Forward Motion Test Ride Carb Issues and Carburetor Tuning Part 26...
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 19, 2014 | 2003 Yamaha YZ 250
17.5 carburetor jetting speedfight 3 AC RS
Hi, Gavin nice novella if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
Life On 2 Wheels
50cc GET Carburetor Basic Tuning
PEUGEOT SpeedFight 3 Workshop Manual
Browse Product Categories
PEUGEOT Speedfight 2 Owner Manual
Mar 24, 2017 | Motorcycles
How to adjust carb on 1973 dt 80 cc
Hi, Cori if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1983 Yamaha DT80 Enduro Part 1 Rebuilding Cleaning Carburetor
Yamaha DT80MX Service Manual
YAMAHA DT50 DT80 MX MULTI LANGUAGE SHOP MANUAL 1981 1984 Download Manuals...
http://mybikemanuals.com/yamaha/yamaha-dt
Mar 13, 2013 | 1973 Yamaha DT 360
Shadow 1100 sabre carb setting on cobra exhaust
Hi, Hitmagedz if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
Honda Shadow 1100 Carburetor Jetting PegMonkey
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Apr 10, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
1988 FZX 750 carburetor tuning
Hi, Sean_evan719 if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
How Motorcycle Carburetors work and how to tune and clean them
Yamaha FZ FZX750 Service Manual 1986 1987 Download Manuals Technical $10
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Dec 01, 2010 | Yamaha FZX 750 Motorcycles
Car has fuel pressure and spark but still won't start-why?
Check your carburetor and the air filter element. Without the air filter out, you can see gas coming out of the carburetor jets as you let somebody start your engine. Gas must get out of it, if your engine has to start. No gas--- get your carburetor jets cleaned. Then, replace your carburetor. Air filter must be free from sludge, otherwise get a replacement..Get this done, and send in your e-mail.
Oct 03, 2009 | 1994 Buick Park Avenue
Honda Horizontal OHV Engine 270cc, GX Series, 1in. x 3 31/64in Logo
90 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
