Question about Electrical Supplies
Hager How do I remove blown fuse, no screws.....
  • Allan Hubbard Apr 16, 2014
    Hi Margie , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
SOURCE: a hager b6 fuse has blown - normally the switch
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Posted on Nov 14, 2009
I am fitting a hager ez003 timer to our board does it need an earth as when we took off the old timer there was an earth fitted we are fitting it through an hager es 420
Wiring diagram for EZ420 delay timer does not show ground or earth connection.
It shows 12-230 volt AC Hot and Neutral, or 12-48 volt DC +-.
I assume the body of the timer is plastic/ cannot be taken apart/ has recessed screws and terminals/ and is double-insulated? Making ground or earth unnecessary.
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/pdf/EZN003_delay-timer-User_Instruction.pdf
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 04, 2015 | Hardware & Accessories
Tip
How to fix your dryer if it does nothing
kenmore, whirlpool, roper,estate,kitchaid,inglis,most of the time if your dryer does nothing you have a bad door switch or blown main fuse,to replace the door switch remove the 2 lint filter screws(top lint filter)pull the top toward you and up,remove 2 screws on old door switch,install new one,to check for a blown fuse remove the back look down to your left and you will see a small white fuse,that is the main fuse-mike
on Feb 11, 2010 | Dryers
I BLOWNED AN ALT FUSE (120A) OFF AN 1999 LEXUS GS BY JUMP STARTING THE BATTERY WITH WRONG TERMINALS. PLEASE PROVIDE SOLUTION HOW TO TAKE OFF THE OLD FUSE. THANK YOU.
depends on type fuse
mini
maxi
some also have screws that hold them down
locate fuse box under hood
remove cover
look for blown fuse, if NOT screwed in just pull straight up to remove, reverse to install new one
if screwed in just remove screws (righty tighty / lefty losy) reverse to install new fuse
May 28, 2011 | Lexus GS 400 Cars & Trucks
Model # jvm1340aw003 I think it has blown a fuse? Where do I find the appliance fuse in the microwave? My email address: claffertysr@sbcglobal.net Thank you in advance for your help, Mike
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and plug microwave back in. control panel should light up.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range microwaveoven worked flawlessly then bang it quit.it looks like its been unpluged but no. I tested the electrica outlet and ther is power. Is there a reset button within the microwave that...
you have a blown fuse.unplug the microwave. remove the vent by unscrewing the 2 screws holding it in place. gently pull vent grill forward to remove. open the door, and remove the screw holding the control panel in place. remove the metal plate being held in place by that screw. inside that panel is your blown fuse. remove the fuse and replace. reassemble the microwave. plug it back in.
Feb 08, 2011 | Panasonic Microwave Ovens
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
Good Morning. The downstairs lights are not working.I checked the fuse box[Hager]and the fuse swich was off for the lights,i flicked this back on thinking lights would come back on [apart from supposed...
I assume you mean circuit breaker when you say fuse. If you reset the breaker to "on" and the lights still don't work, look for a GFI outlet somewhere in the circuit. It could be tripped which will shut off the current downstream from it if it is set up to guard the downstream circuit.
May 26, 2010 | Electrical Supplies
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove...
Sep 12, 2009 | Electrical Supplies
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
How to Remove the Back Cover to Replace the Fuse
unscrew all the back black screws and gently pull the back off.
if a fuse is blown, you most likely have a severe power supply issue.usually the str would be shorted , a bridge rectifier wil also do this, a faulty ptc will blow a fuse also.
check how the fuse blew, if it looks violent then you have a short.
Jul 09, 2008 | Panasonic CT-32HL43 32" TV
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
