Question about Motorola Mobility H700 Wireless Headset
How do I pair motorola h700 with motorola defy?
Pairing motorola h 700 with motorola defy
  • Official Brand Answer
  • 1,623 Answers
Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
Mark
Motorola Support
Posted on Feb 10, 2015
2 Suggested Answers
josema_sv
  • 512 Answers
SOURCE: trying to pair my phone
When pairing a computer with a cellular phone, you can set your own 4 digits passkey, which must be entered at both devices upon request.
In the following link you can download the user guide:
http://www.motorola.com/staticfiles/Consumers/Products/Mobile%20Phones/MOTOROLA-DEFY/_Documents/_Staticfiles/DEFY_UG_SA_EN_68014561001.pdf
Posted on Feb 20, 2011
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
How do i put the motorola h700 in pairing mode
Hi terantra,
I would like to assist you with your Motorola H700 headset, Please see steps below.
  • Make sure that there are no other Bluetooth devices in the area.
  • Now set the device that you want your Motorola H700 to pair with make sure that it is detecting devices.
  • Now on your H700 Motorola press and Hold down the Multifunction Button on it, and open the mouth piece.
  • This should be detected right away by the device that you are pairing the with the H700, the pairing Code for this H700 will "0000"
I hope that his will be of help regarding your concern.
Have a nice day,
mvincent
Apr 22, 2011 | Motorola Mobility H700 Wireless Headset
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 for Treo 700
4 zeros is the pass key. try powering off and on your phone and headset put your headset in pair mode by holding down on the power button until the blue light stays on.
Feb 04, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
123 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
