Question about Health & Beauty
I have a invacare meteor scooter and it slows down and speeds up can you help
naic98
  • 23 Answers
SOURCE: ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
Posted on Mar 21, 2009
gewiz
  • 1271 Answers
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Posted on Oct 06, 2009
gewiz
  • 1271 Answers
SOURCE: I have a Go Go scooter that is an older model. It
Hi, That sounds like the speed pot is faulty,
When going along push the lever in the upwards direction as well as forward , does it speed up ? does it response ? if so then that's the problem.
There could be a issue with the metal key making a good contact when inserted.
Regards
GeWiz.
Posted on Dec 24, 2009
  • 177 Answers
SOURCE: I rolled my meteor scooter and hit a curb.bumper adjustment
Hi. You are probably better off by unbolting the bumper and then fixing it. It is held on with two 8mm bolts. You will need two 13 mm spanners to unbolt it. It will be much easier to fix it on the work bench.
Good luck. Neil.
Posted on May 30, 2010
mcdevito75
  • 1970 Answers
SOURCE: I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
Posted on Jun 23, 2010
I have a problem with invacare meteor scooter ,it randomly wont go forwards,most consistant thing i noticed is it jerks to a stop,after that it wont go forward and flashes 8 code/motor fault
Hi AGAIN HAVE TESTED the SPEED CONTROL potentimeter & WIG WAG FOR THERE CORRECT RESISTANCE IN OHM'S .ANOTHER POSSIBILITY IS THE LITTLE COMPUTER ( CONTROL BOX )IS FAULTY good luck get you're batteries LOAD TESTED..ERROR CODE 8 IS ALSO A MOTOR VOLTAGE ERROR cheers
img_20180518_192320-2n4i1ve51ezgzxt22yhmjm2x-2-0.jpgimg_20180518_192502-2n4i1ve51ezgzxt22yhmjm2x-2-2.jpgimg_20180518_192502-2n4i1ve51ezgzxt22yhmjm2x-2-3.jpg
May 18, 2018 | Invacare Health & Beauty
How often do I charge invacare Leo mobility scooter?
when the batteries run low
there should be a volt meter for this indication or when the unit slows down
Jul 10, 2016 | Invacare Leo 4 Scooter Scooter Silver -...
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
Invacare meteor, keeps slowing down, then speeds up again, can you help.
usual cause of this is the throttle (wig-wag ) controll potentiometer has worn out.to test put the scooter against a wall and get a freind to lift up the rear of the scooter and put 2 large blocks of wood underneath it so the back wheels can rotate
carefully advance the throttle 1/2 way then with wheels turning.keep in same position and gently move the throttle lever up and down .if there is a lot of play and the speed varies drasticaly then pot replacement reqd .you can get a dealer to order the correct one or get one off the internett but when fittinf if thr pot is not set to exact center with multimeter scooter will not move and produce off center error code
Sep 27, 2014 | Invacare Health & Beauty
How do I turn off the pronto m41 speed limiter
The Pronto M41 does not have a speed limiter per say. If the chair used to go faster than it does now then you may have some kind of problem with the chair. If the chair has always driven' slow, that is slower than the maximum 3.5 to 4 MPH then a Invacare Remote programmer is needed to program the chair to go it's full speed.
Seek a Invacare dealer and ask them if they can check the programming.
May 16, 2014 | Electric Mobility Invacare Pronto M41...
Panther lx4 runs irregularly .batteries are brand new. ride well for 10 minutes after it starts to slow down then accelerate then slow down etc...
Most scooters have only a rheostat to control speed. Over time, the carbon will wear and cause erratic control.
Oct 14, 2013 | Invacare Panther LX-4 Batteries
New battery. hooked up correctly. But, scooter will still barely go in reverse super slow. forward speed slow .can throttle cable be problem/ when I push inside of speed lever it moves faster. pushing ends...
Hi. Did the machine used to operate properly in the past? Sometimes previous owners or technicians have changed the programme for owners for different uses. What you describe sounds like a faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors.
Do you have another switch on the machine for controlling the speed, such as an indoor/outdoor switch? Good luck. Neil.
May 12, 2010 | Activeforever Lynx L4 Portable Mobility 4...
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Jul 28, 2009 | Invacare Supply Group Invacare Scooter...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
