Question about Samsung B2030 LCD Monitor
Samsung B2030 LCD Monitor, connect tv tuner card
dhecom
  • 233 Answers
SOURCE: want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Posted on Feb 10, 2010
SOURCE: Want to connect this to a laptop via USB. Is this
not possible connectin with usb ,possible with only vga and dvi
Posted on Jan 30, 2011
engineerayo
  • 169 Answers
SOURCE: when i am on the computer the lcd monitor samsung
there are there are 3 approaches to this type of problem so the first ine is for you to check your Memory RAM if is OK by using another one to check your system
the second one is for you to check your computer with another monitor
the last one is for you to check your system VGA (visual graphic adapter) onboard or better still if u are getting confused you need to see a computer technician,
Posted on Feb 12, 2011
budmrtn
  • 11361 Answers
SOURCE: samsung 20" LCD monitor B2030
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Feb 25, 2011
tobibus2000
  • 506 Answers
SOURCE: Is the Samsung B2030 LCD
Yes it is. it supports any recently built software because it was built to do so.
Posted on Aug 19, 2011
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
I cannot turn up the volume on my monitor
The Samsung B2030 LCD Monitor has no speakers, you cannot turn the volume up on it. Instead turn the volume up on the speakers, or on the computer itself.
Aug 26, 2011 | Samsung B2030 LCD Monitor
Is the Samsung B2030 LCD Monitor software compatible with Ubuntu 10.10?
Aug 19, 2011 | Samsung B2030 LCD Monitor
Samsung 20" LCD monitor B2030
OSD Lock & Unlock
lock function.
lock function.
Feb 25, 2011 | Samsung B2030 LCD Monitor
Want to use samsung 2233SW LCD monitor as TV
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Tv tuner card is not supporting with lcd monior
I think that would be the other way around. You need to replace it with a card that supports LCD monitor.
May 03, 2017 | Acer AL1916W 19" LCD Monitor
Tv tuner card is not supporting with lcd monitor
The intex it 3488 tv tuner has known compatibility problems with this particular Acer monitor: see here.
If the tuner card is new see if you can get a refund, by claiming it as faulty, after all this is a factory fault.
Sep 08, 2008 | Acer AL1916W 19" LCD Monitor
Samsung B2030 LCD Monitor Logo
20 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
