I can't get any sound from my Pure PocketDAB 1000 digital radio even though I have full signal strength and radio stations selected. The earphones are working on other devices but I just can't get any sound.
  • lionel493 Jun 18, 2009
    Hi, I have just received my Pure Digital PocketDAB 1000 and I can?t get any sound from the headphones. I have stations selected, power, Signal strength 100, I have tried another set of headphones. What am I doing wrong?
  • 10,515 Answers
Make sure your PocketDAB 1000 Is plugged in or has batteries inserted and is switched on as shown in your user manual.
Check the volume level, It should not be too less.
Ensure that you completed the Autotune procedure to find digital radio stations as mentioned in you user manual.
Any further help, ask me.
Thanks for using "Fixya".
Posted on Jun 18, 2009
  • 240 Answers
Please do the below procedure to fix your problem
1.Make sure your PocketDAB 1000 is plugged in or has batteries inserted and is switched as per the correct configuration. if u have batteries try inserting a fresh set of batteries as the old one may have less charge.
2.If everything is fine in battery then Check that the volume level is not set too low. Ensure that you have completed the Autotune procedure to find digital radio stations.
i will give u a link it will be very much useful to you inthe future for various trouble shooting purpose and knowing the exact configuration of your digital radio. www.pure.com/Support/Manuals/VL-60672/User_Guide_-_267KB_PDF.pdf
please rate my solution if you are satisfied.
    Brigadier General:
  • 8,619 Answers
Hi
Please check all the connections. You can open the unit and try to clean the dust. Check for burned wires, cold solder joints, burned capacitors/transistors and replace the component that is not fine.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Problem with my earphones.samsung shg-j700
go to options while you are listening to music & then select "earphone on"
Jul 24, 2012 | Cell Phones
My radio skips over a channel and I'm not sure why. Can you help?
There are two main areas to look at, one is signal strength. Many units have a threshold that is will allow stations to be selected. if the signal is weak, the tuner will not stop there.
The other common issue is Genra selection. If you have selected Rock, and the station that you want has listed something else, that will stop tuner from stopping on that station.
Feb 05, 2011 | JBL REM45 Remote Control
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
26" ILO digital T.V . won't pick up digital signals w/digital antanae.\r\nusing air in setup
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Sep 11, 2010 | iLO 2600 Television
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
I have a Sony icf 2010. No sound, but white noise.
AA batteries need replacing or the contacts are corroded and one more, the PC board is connected to the AA negative post by a wire that touches the pad on the PC board. Sometimes it will lose contact because of oxidation or corrosion, to fix this a wire soldered is best but just repositioning the wire will make the cure. Requires removal of the circuit boards.
Jan 20, 2010 | Sony ICF-2010 AM/FM/SW Radio
No sound after dropping S350.
Probably one of two things:
The dropped caused the speaker leads from the PCB to Speaker to disengage (check the earphone jack, too... 'cause it is in the circuit)
or
The bounce cause the Audio amplifier IC to become desoldered from the PCB.
Mar 06, 2009 | Grundig S350 AM/FM/SW Radio
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
54 people viewed this question
 Grubhead
Grubhead
