Question about JVC GR-D250 Mini DV Digital Camcorder
Audio drop out and/or static sound
Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
3 Suggested Answers
Kimi
  • 277 Answers
SOURCE: JVC GR-D250 does not record properly
When playing the tape in the camera itself, do you hear sound? If so, its something with the connection cable... is not, you will need a professional repair, you can do nothing except the head clean which you did? Sorry.
Posted on Nov 23, 2005
  • 19 Answers
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Posted on Dec 21, 2007
Static on jvc hd-56g786
I will presume same issue when playing a DVD etc via a rear input.
Other suspect is a cable box if connected via audio and video jacks.
This model is prone to the audio board failing---entire sound circuit is on one board with the tuner etc---usually no sound but your problem is possible.
Dec 04, 2012 | JVC Televison & Video
Recording using 5.1 live sound card
Did you check the cables connected are not damaged
Apr 17, 2008 | Creative Labs Sound Blaster Live! 5.1...
How to troubleshoot sound problem on I ART PRO JVC 56. No sound.
A low buzz suggests the audio detection circuit in the set may have failed---I would first see if a DVD connected to a rear input works or not--rules out almost anything except the audio circuit in the set.
I have seen a number (need a model number) where this happens--audio is detected and most of the sound circuit is on one board---had one of the DLP sets a few years ago almost brand new with this issue---board was not available yet so set go exchanged and JVC told us to keep the set.
With a scope I traced audio from the tuner in the set into the audio output and the defect was there--no parts for set so placed board on order (backorder) and 3 weeks later it arrived and I replaced it (40 minute job as sandwiched in the set---sound now perfect.
Point here is if on that board you are going to have to replace it or send it out for rebuild (not to JVC).
Check first if you have not that a DVD alone either does or does not have the same problem.
Aug 28, 2012 | Televison & Video
I have a JR-S501 receiver that cuts out on the sound. The turntable works OK when hooked to another amp. Thanks for the help
So are you saying you have a turntable-only issue with the JVC (guessing about the brand)?
Does the JR-S601 work OK otherwise?
Given its vintage there could be oxidized contacts throughout which would cause crackly sound or total silence.
If it's only an certain source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Have you looked in the manual?
Mar 23, 2011 | JVC Audio Players & Recorders
I am repairing my friends Nintendo Wii. There is major static issues with the sound. She says the static comes from the TV. I am wondering if the issue is due to a bad AV cable or if it would or could be...
If it's coming from the AV cable, the white plug (AUDIO L) and the red plug (AUDIO R) are most likely not plugged in properly. Make sure both audio plugs are firmly plugged in. Like I said, if it's coming from the cable, this problably is what's wrong.
Feb 27, 2010 | Nintendo Wii Console
My car speakers cut out when i turn my volume to loud what could the problem be i have stock speakers in a 02 chevy truck and a brand new jvc radio
Hello soccer_fr704,
Sounds like the JVC is overdriving the speakers. Most OEM speakers are just not designed to handle more than 12-15 watts RMS and the JVC is rated at 22 watts.
About the only solutions are to keep the volume really low or replace the speakers with ones that can handle the power from an aftermarket receiver. New speakers will make that JVC sound better, too.
Hope this helps.
Jul 09, 2009 | JVC Car Audio & Video
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Dan
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
No Audio:
Ron,
it sounds like a dry joint to me. Look at the obvious places first, such as the amp as you mentioned. Anything that heats up and cools down will give problems, as I am sure you are aware. It could be a thermal issue. Has it always done it since new? thanks ST
Dec 06, 2007 | Sony DVP-NS530 DVD Player
JVC GR-D250 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
