Question about Garden
How to adjust a drive belt on a 1981 craftsman GT6000 lawn tractor
2 Suggested Answers
lonewolf1996
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
Craftsman GT6000 steering is toed out, seems to be no adjustment
chances are axles could be slightly bent , simple fix is to have the arms made adjustable by cutting,threading and sleeve as like adjustable tie rods on a car.
Tie Rod Assembly with Clevis Ends Tie Rod Assemblies Anchors Anchor Bolts...
Sep 14, 2015 | Craftsman Garden
Fitting new drive blet
just loosen the adjuster and when it loose pull-out the loosen belt and replace with the new one and retight the adjuster at exact belt tension
Jul 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in Deck Lawn Tractor jerks/bucks when in forward during turns. Is there an adjustment or do I need a new belt?
Sounds like to me you need a new belt! The belt is automatically tensioned by a spring on most mowers by MTD, the major mfr for most mowers including craftsman.
Apr 20, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need drive belt diagram and instructions for replacing the drive belt on a craftsdman dlt 3000 lawn tractor.
Your mower will have a model number like this one:
917.275820 The pictures in the manual below are for the 18.5 - 20 Hp 42 inch deck riding mowers.
It brings up this manual: (3.71 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411347.pdf
See page 23 under service and adjustments for deck belt routing picture.
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 hp 42 " automatic craftsman . The trans seems to be slipping,does not want to go up any incline. I have purged it and installed a new drive belt. did not help.
recheck ur drive belt either wrong belt or spring/idler/tentioner pulley needs attention adjustment replacement also check free wheel actuator that not partially activated
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman gt6000 18hp kohler garden tractor. I has been working fine, but last week I noticed a loud single click when i turn on the ignition and a loud single click when i turn off the ignition....
The noise is likely coming from the starter solenoid which is the heavy duty relay that sends battery power to the starter motor. If this is the case clean the wire connections going from the battery, to the solenoid and to the starter and try it again.
May 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
