Question about Whirlpool Refrigerators
Ice slab buildup at freezer bottom
Continuous ice slab buildup on freezer bottom
dididsaythat
  • 291 Answers
SOURCE: Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Posted on Aug 28, 2007
22yooper
  • 828 Answers
SOURCE: Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Posted on Aug 09, 2008
  • 531 Answers
SOURCE: side by side leaks out front door on freezer side
you may have defrost problem
Posted on Apr 07, 2009
  • 4 Answers
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
Greg20
  • 149 Answers
SOURCE: Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Posted on Jun 13, 2009
Bottom freezer door causing ice buildup
If the refrigerator is not defrosting the defrost heater assembly might be burned out. Several times a day the defrost heater assembly turns on for a few minutes to melt away any frost that may have accumulated on the freezer or refrigerator evaporator coils. If it fails, frost will build up on the coils and eventually no air will be able to travel through the coils to provide cooling. The defrost heater can be checked for continuity. If it doesn't have continuity it should be replaced.
Next chance is the defrost thermostat might be defective. This signals that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater and create the same problem you mentioned. It can be tested for continuity when it reaches the low temperature of its operating range.
You may also have a bad main control board that tells everything to work when it is supposed to such as telling the defrost heaters to activate or interpret the thermostat message that it is time to defrost.
Jun 12, 2014 | GE Profile Bottom-Freezer Refrigerator...
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
My freezer has ice on the bottom,we keep cleaning it out and the ice keeps coming back
I need to ask, what kind of ice are we talking about, ice cubes or a slate? If cubes there is a gage that can be added to the ice maker arm to prevent this. If its a slab or slate, than I would look at the defrost drain system in the back of the freezer to be clogged. If no ice there, is it possible not all the water from the ice maker is getting into the ice maker?
I hope this helps or leads you in the correct direction.
Aug 17, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
Freezer is very cold but fridge area is warm. what is up.
Sometimes the defrost drain pan stops up. Instead of the water goin outside is pools up between the compartments. This forms a slab of ice and blocks the air flow from freezer to fresh food. Of course the other thing that comes to mind is the freezer fan could have quit or stopped due to an ice buildup.
Feb 13, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
It's too cold in the top freezer, yet not cold at all elsewhere
if your freezer is cold but your fridg isn't then you have a defrosting problem. behind the back wall of your freezer you will probably find a very large mass of ice. unplug your ref and using hot water melt the ice. you will need several large towels for this since it will make a mess. once the ice is cleared if you have an ohm meter you can check the defrost element you are looking for continuity( closed circiut) if that tests ok find the defrost termintor(also called a bi-metal defrost) it is about the size of a quarter and is usually located in the top left side of the freezer. It will be clipped to one of the tubes. if it looks like it has popped then it is bad. If the bi-metal looks ok you will need to hook the element back up and go to the control panel in the fridge. looking up at it you will see a small hole and a gear inside that you can turn with a slotted screwdriver. turn it until you hear it click and the fans stop running. if the defrost heater comes on then change the defrost timer(the part you just turned)
Apr 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge w/freezer on bottom will not chill
What you have is probably a bad defrost heater element is my first inclination. I would look for frost buildup on the backside of the bottom drawer. That is a sure sign of defrost failure. And most defrost failures turn out to be broken heaters. The defrost heaters mount on the evaporator coils and simply heat the area for a few seconds to melt frost. If left alone that frost will trun into snow and then into air flow blocking slab of ice and fail fresh food cooling. I have a 3 door repair manual you may want to look through just to see what you are up against. To do this repair the ice maker and all the rails drawers bins and food must come out so you can get to the rear where the evap coil and defrost heater is located.
LG FRENCH DOOR REPAIR MANUAL
Feb 14, 2010 | Refrigerators
Layer of ice formed on the bottom of freezer and a layer of water with no obvious source has formed on the top shelf on the right side.
That is an easy one. Instead of the defrost liquid draining down the drain hole it is blocked and a slab of ice is forming. You must thaw out the ice box and clear the drain hole. Another thing that could cause this slab of ice could be a leaky ice maker water valve or a faulty ice maker pumping in too much liquid into the ice mold.
Jan 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Ge monogram ice maker makes loud churning noise. Any suggestions
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Jun 12, 2009 | GE Monogram ZDI15C Automatic Icemaker
Refrigerators Logo
12 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
