How to unlock grundig tv 37-640 text
The tv doesn`t work properly when you use the remote to turn the tv on, even though you a sound that seems the tv is on but on the screen there is nothing on it. looking forward for help. Thanks
chrispurs1
  • 372 Answers
SOURCE: How to unlock Grundig T55-1020 pincode
Hi.
Unfortunately there is no magic code that you can enter to undo the pin code lock.
This is how its done but you will need A repair shop to do it.
Place set in to protect by entering any sequence of numbers 3 times,
Connect a 390ohm resistor between w129 (ground) and pin 56 of the micro,
Press button 7 on the remote for a minimum of 6 secs.
And thats it unlocked.
Sorry its not a simple fix.
Chris..
Posted on Nov 26, 2007
SOURCE: Blurry text on 27-inch Zenith "Sentry 2"
If your still looking for answers ... I have the access sequence to get into the SERVICE mode ... where you can adjust convergence. send email to
atcs<at>optonline.net
Posted on Aug 12, 2008
  • 10 Answers
SOURCE: Magnavox TV does not turn on with remote
turn it on bye the SCREEN...
Posted on Mar 16, 2009
  • 476 Answers
SOURCE: tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Posted on Aug 05, 2009
barbu51
  • 566 Answers
SOURCE: remote control chkt1a for apex tv does not work
You may have bad solder joint inside the remote and especially on the l.e.d at the front, happens often(remote dropped etc.). If you have a soldering iron you can open it a make a round of the solder joints, it should fix your problem. Hope this will help.
Posted on Dec 02, 2009
Grundig p40 540 text
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 21, 2014 | Televison & Video
Grundig rc 7 1 universal remote doesn't work properly on loewe tv
Universal remote controls do not necessarily manage all functions of a particular TV. You may have to try a different universal remote control.
Sep 04, 2017 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Hi tommorow my tv A grundig P37-830 text saw on my screen A bar and says ats ok and I cant to change channel and my remote control doesnt work what can I do?
hello, I had the same problem. I tried everything, after 14 days, where was TV off a tried it again...an the same problem: text " ATS... OK " So a tried hold 3 seconds on Grundig driver button "OK" and then the started automatic tunnig. After it - averything is function! :)
Jul 03, 2010 | Televison & Video
Grundig Cinemo TV will not start
The power supply could be failing.
Jun 02, 2017 | Grundig Televison & Video
User owner's manual Grundig T55-732/5 text
Dear......
My father in-law who has died used to own a classic 14" Tv Model T 20-6210/6, with a remote control Model TP 711, when I switch it ON a Key with 4 stars shows up, I tried few numbers including 0000, but unfortunatly no luck,
pls. advice for the following:
1 - what is the (manufacturer) original password (key password)
2 - If I need to reset it where is that and how
3 - I need to reprogram the TV how is that
Knowing that :
- I do not know german language and I have been adviced by Grundig main site to download from Buchproduktion.......
Many thanks in advance
Eng. Nazir Touma (Lebanon)
May 13, 2010 | Televison & Video
Grundig Televition (P37 830 Text) shows only one channel with an
hello, I had thesame problem. I tried everything, after 14 days, where was TV off a tried itagain...an the same problem: text " ATS... OK " So a tried hold 3seconds on Grundig driver button "OK" and then the started automatictunnig. After it - averything is function! :)
May 03, 2010 | Grundig GF70-600 TV
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
