Question about Microlife Health & Beauty
How to delete memory from microlife bp monitor
How to delete the past history/memory usage
3 Suggested Answers
SOURCE: Program date and time
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Posted on Feb 13, 2010
SOURCE: I have a 3MQ1-LF bp monitor. I am trying to
To erase the monitor's memory, press and hold the "M" button until the letters "CL" appear on the screen. Release and press the "M" button again. The monitor will beep twice, indicating that the memory is now empty.
Posted on Apr 05, 2010
How do I clear the memory on a Microlife 3MC1-PC blood pressure monitor?
Turn it off, Hold down the "M" button until "CL" appears and press "M" while "CL" is flashing.
May 09, 2015 | Microlife 3MC1-PC Blood Pressure Monitors
Cuff does not get full inflated even after getting it properly applying error3 appears,I m a Doctor
replace batteries,or there is a leak,you didnt say which bp machine it was so go here and find your machine to get the user manual for it, Microlife Manuals
Apr 02, 2015 | Microlife Health & Beauty
I have digital blood pressure monitor Model bp3bm1-3.it is not turn on, why ?
i have micro life bp aparatus since 3 years but from last month it diosent work good every attampt it indicates low blood presure at all on screen it dosent go up by 140 and all the time it shows 90 / 50
please advise what to do
Sep 27, 2012 | Microlife 3AC1-PC Blood Pressure Monitor
How to clear memory on a microlife bp 3ar1-3p
With power on, showing only clock.
Press M button, then press Power button together.
About 10 seconds, it'll display CL on screen.
Lift up your finger, CL will flashing.
Then press M button once, you'll hear 3 beep
Done.
Jul 08, 2012 | Microlife 3MQ1 Blood Pressure Monitor
How do you erase the memory? It states memory full! I removed the batteries but it does not delete the memory. Where do I download the book, I lost it. Thanks
CVS Pharmacy stock and sells your model BP Monitor. I suspect if you either called their closest location to you or stopped in, they would be happy t make you a copy of the manual from one they have in stock.
Hope this helps you get another manual.
Mar 07, 2011 | Life Fitness Ultra Blood Pressure Monitor...
Mar 15, 2010 | Life Fitness Health & Beauty
Readings vary widely withing 5 mins. when repeated
You should not recheck BP until at least 15 minutes after the first check because it will always get higher on reading even with a manual BP machine. As a retired nurse I have both an automatic HoMedics which I I lost the manual for and a old type arm BP cuff. My automatic is pretty close to the other cuff in readings so I know it is close. Try waiting for a while before you recheck and not talk or move around when you take it.
Mar 10, 2009 | Health & Beauty
Health & Beauty Logo
77 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
