Question about Coffee Makers & Espresso Machines
How to take apart jura ena 3
I'm trying to clean the grounds out of my machine and would really like to remove the cover but can't figure it out.
3 Suggested Answers
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
CoffeeLoverZ
  • 33 Answers
SOURCE: I cant get the coffee grounds container out. I
Be very careful if you are too rough then it can uncilp the flap, try and open the tray a little then with a pencil lift the grounds container up and slowly ease the tray out
Posted on Feb 12, 2010
My jura impressa 9 keep saying not enough coffee no matter what i do
bad sensor, you can try blowing area clean with compressed air, pres the helpful button
Jan 30, 2016 | Jura ENA 3 Automatic Coffee Center - Black
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura ena don't grind coffee
new grinder teeth
Dec 27, 2013 | Jura ENA 3
JURA ENA 9, GROUNDS TRAY WILL NOT INSERT IN MACHINE
Hi, I made a video on YouTube how to fix your Jura step by step
like my video, good luck
http://www.youtube.com/watch?v=KP_KvZs1wLY
Aug 15, 2013 | Jura ENA 9 Automatic Coffee Center
Ena 3 troubleshooting: Right now it appears that the right coffee spout has a weaker flow than the left. Is it clogged? How can I fix it if it is even broken. Thanks!
Got it! It took me two months and the parts diagram to figure it out.
http://www.jura-parts.com/v/vspfiles/diagrams/Jura%20Impressa%20ENA%203,%20ENA%205%20Diagram.pdf
Use a water-flosser... I used like 8 full water tanks and DONE.
The simpler way would be to try to point up the water-flosser through each of the four holes of each spout... It will be a mess but it should work.
The other way:
1.- Take the grey plastic panel out from the front dispenser. Use a small flat screw-driver, start from the top, there are 2 clips, and then 2 other clips on the bottom.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-0.jpg ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-2.jpg 2.- You will see the dispenser "inside", a two black tubes with the spouts at the end and an air intake (I guess) on top. Take out the air intake, that will let you have access into the tubes with the water-flosser.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-9.jpg 3.- Take your time "flossing" your dispenser, as I said it took me like 8 water tanks... a lot of coffee residual got accumulated (to my surprise).
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-14.jpg 4.- Voila!
Jan 29, 2011 | Jura Capresso Jura Ena 3 Espresso Machine ...
Coffee Makers & Espresso Machines Logo
54 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
