Fix maxtor ares c64k - Computers & Internet
How do i fix my maxtor
You have not stated what sort of problems you are having with your maxtor hard drive.
Click start right click on my computer you should see your drive usually C: select properties Click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors check now start should schedule this task when restart.
You should have no input while the chkdsk utility is in progress any input may damage your computer.
Nov 27, 2012 | Maxtor Computers & Internet
A whirring sound , then it went dead as if nothing is happening inside there,the PC do not recognige the HDD.
maxtor hard drives are really really unreliable one way to get it going is to hit it on a hard surface,the disc inside sticks and hitting it gets it going again.
this is only a quick fix i would suggest that you transfer the data on maxtor hard drive onto another drive
John
Feb 23, 2011 | Maxtor Hard Drive
I would like to clean, erase the contenue of my Maxtor... how to do it??
If you are operating in Windows. click "START" and then "COMPUTER" or "MY COMPUTER". a screen will appear with all fixed and portable drives hooked up. Find the Maxtor hard drive and RIGHT CLICK it. In the drop down menu choose "format". this will erase EVERYTHING on it so make sure you have saved anything you want to keep in another place.
Dec 27, 2010 | Maxtor OneTouch III 300 GB Hard Drive
The Maxtor harddrive was moved and the plug got jiggled so it wasn't showing on my pc...I fixed the issue, then kept getting an error message "checking dish one touch" with 2...
Open My Computer
Note the drive-letter assigned to the Maxtor
Close My Computer
Click Start
Click Run
Type CMD
Press Enter
If the drive-letter was 'E:', type 'E:'
Press Enter
Type ATTRIB -H -R -S *
Press Enter
Open My Computer
Double-click the icon for the Maxtor
Does it still show "zero" files/folders?
Does it show a 'FOUND' folder?
What file(s) are in that folder?
Nov 02, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Hi, I have a maxtor personal storage 3100 on which I have data that has been stored from my Dell Dimension computer that has XP. I want to transfer the information to my new DELL Studio computer with...
this message comes mostly due to the nonavailability of the drivers. so i would request you to first install the drivers of your maxtor personal storage 3100 to your DELL studio computer, then connect your maxtor storage to your DELL computer. this should fix your fix your issue.
Dec 08, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor OneTouch III 500gb
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Feb 24, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
David Payne
David Payne
