Question about Vehicle Parts & Accessories
I HAVE A 1996 C280 MERCEDES BENZ. IT WILL NOT CRANK. I PUT A NEW CRANK SENSOR AND A TENSION PULLEY AND ALSO FUEL PUMP AND A NEW PROGRAM KEY BECAUSE I THOUGHT IT COULD BE THE SECURITY SYSTEM BUT IT
I NEED HELP CRANKING THIS CAR.
  • Alan Smith Apr 13, 2014
    Hi yolanda richardson, I want to help you with your problem, but I need more information from you. Do you have power to the starter? I don't know what you mean by won't crank. I am thinking you mean it does not turn over at all.
    Sergeant:
  • 244 Answers
Check the battery
Posted on May 25, 2014
98 c 280 key fob problem.transponder came loose key fob sat without batteries in it for a couple of days.resoldered and did it right.still wont recognize key fob doors or ignition
Key Not Detected Message? - Mercedes-Benz Forum
www.benzworld.org > ... > Mercedes-Benz Sedan Forums > W212 E-Class
Feb 2, 2011 - 10 posts - ‎9 authors
Did you also try the 2nd key to see if the problem still exist? If not, then that particularkey fob needs reprogramming. Decboy is offline.Missing: 98
Car Shutting off and won't start occasionally - CarGurus
www.cargurus.com > Questions > Mercedes-Benz > M-Class
CarGurusApr 16, 2009 - Car Shutting off and won't start occasionally - I have a 2000 ml430 and my ... today and now my SUV has started and will post if the problem still happens. ...when I try to restart after it dies, the ignition goes into a continuous crank. ... My car has the same problem, I'am starting with a new engine key, cam ...
Key FOB only works on IR - Mercedes Benz SLK Forum - SLK World
www.slkworld.com > ... > SLK R171 General Discussion
Dec 15, 2013 - 17 posts - ‎7 authors
My key was not in the ignition when he attached the hot shot. ... After the install, mykey fob no longer would unlock the doors or trunk, ... Check your radio reception in the car, and see if you can pick up ... The problem still persists. .... but if you have it next to the radio antenna, it will not lock/unlock the doors?
c250 sport no crank - CLUB202
www.club202.com > Forum > CLUB202 > Repairs
May 3, 2011 - 22 posts - ‎7 authors
1998 C43 ... Put the key in run the shift selector thru all the gears and back to park. ...just after trying there no difference, just gets to ignition then nothing happens ... for them. if I had a dime for everytime I've had to jump start my 94 C280. ... fob is good, transmission is in Park or Neutral, and the engine won't ...
Jan 31, 2016 | Mercedes W202 C230 C280 Rear View Mirror...
1995 c280
check front pulley area or fly wheel housing area.
Aug 10, 2014 | Vemo 1994 - 1995 Mercedes-Benz C280 Engine...
Belt replacement 2003 ml500
It is fairly straightforward on the M113 V8s. I can't remember if that automatic tensioner has the 15mm socket spot on it just under the tensioner pulley or not. The tensioner is located on the driver-side lower but next to the power steering pump pulley. Move it from YOUR right to left, when facing the engine and remove the belt. Put the new belt on starting at the crank pulley. The rib side routes all the way around the idler pulley-from the crank shaft, Power steering pulley, top guide/idler pulley and then alternator on the lower right(passenger-side). The back or smooth side goes around the tensioner and water pump.fan pulley. I hope that helps.
Aug 01, 2014 | 2007 Mercedes-Benz ML500
I have a 1999 Mercedes-Benz ml430 i need a diagram to finish putting on my serpentine belt can you help me
I cant find a diagram however i can tell you how it goes. Starting at the alternator the belt goes completely around alternator (ridge side to pulley). pulley then over the water pump pulley (smooth side to the pulley), then down to the right around the tensioner pulley (smooth side to the pulley), then back to the left up and over the crank pulley (ridge side to the pulley), then to the right around the ac compressor (ridge side to the pulley), then up over the power steering pulley (ridge side to pulley) and then finally to the left over the idler pulley. have a good day.
Mar 11, 2011 | 1987 Mercedes-Benz 300-Class
I have a 1996 c280 and up until last week had not had any problems so far with it starting, and so i turned it off as usual and then later on when i went and tried to restart it, my car it won't start it...
Welcome to FIxYa.com
Location of fuel pump
Crimp line coming from fuel tank and remove clamps and fuel nuts to pump remove mounting. Install new fuel pump
Regards, Lee Davidian
Thank you for using FixYa.com
Nov 03, 2010 | Mercedes-Benz C-Class Cars & Trucks
Hi i've a 95 c280 benz.the car dont start.
you said fuel rail has pressure , why do you want keep checking fuel system?
check ignition , and if no spark present check reference sensor(crank position sensor) , if it's bad you won't get spark or fuel.
Apr 29, 2010 | 1995 Mercedes-Benz C-Class
I have oil leaking from in the front, bottom of my 1999 mercedes c280 sport car. what is the name of that gasket?
oil pan gasket is on the bottom, the one behind the crank pulley is the front crank seal
Feb 25, 2010 | 2007 Mercedes-Benz C230 Sedan
The c280 just switched of whilst driving just cranks but does not
Did you receive an answer to your problem ? My duaghter is having a similar problem with her vehicle.
Jul 20, 2009 | 1995 Mercedes-Benz C-Class
How do I replace a fan belt on C280 model with air conditioner
You find a 17 mm bolt under the belt or a 15 mm bolt in the middle of the tension pulley. If you undo the bolat this will release the belt tension.
To remove the belt turn the bolt by slipping a 4' pipe over the socket wrench handle.
Use a wrench as a lever to slide out the belt. Put the new belt last on the idler pulley that contacts the belt only on the smooth side.
Do not unscrew the Button Torx bolt in the center of the tension pulley, it is not needed.
Sep 01, 2008 | 1995 Mercedes-Benz C-Class
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
