Question about Toto ST454E Eco Drake II E-Max Toilet Tank
Toto ST454E Fill valve hissing - Toto ST454E Eco Drake II E-Max Toilet Tank
4 Suggested Answers
  • 127 Answers
SOURCE: changed the flapper on my toto toiet and yet still
changing the flapper will not help the fill valve if it is not shutting off. It is not shutting off all the way once the water fills up, you either need to replace the seal in the fill valve or replace the fill valve. They can get grit in them or get scaled up and they stop working properly.
Posted on Oct 24, 2009
  • 299 Answers
SOURCE: TOTO toilet Gmax fill valve
You need Korky Part # R528 available at Home Depot. Instructions are on the package and it takes just a few minutes to change it.
Posted on Apr 18, 2010
  • 17 Answers
SOURCE: The bowl on one of our Toto Drake toilets, after a
The small tube that comes from the Korky fill valve needs to go down the center of the tube in the tank. It should have come with a clip to clip it inside the fill tube. If the tube is running water into the tank it is just filling up the tank, not the bowl. The tank is filled with the Korky valve from the top of the tower, not the black hose. See the video below to see the black tube I'm referring to and where it should be attached.
http://www.youtube.com/watch?v=bfE8gBV0gHI&feature=player_profilepage#t=92s
Posted on Jan 10, 2011
Toilet fills up and water keeps on running (toto 6.0 lpt)
If any toilet runs (continues to fill) when it is not being used, there are basically 3 reasons. the most obvious is that water is leaking out all over the floor so the fill valve thinks the tank has not reached its volume of water. Next, the rubber device that keeps the water in the tank when not being used (most commonly called a flapper) has warped from time or chemicals in the water (NOTE:chlorine eats rubber for breakfast daily), and and allows water to seep past it, which lowers the water level and triggers the fill valve to come back on to top things off.
The third reason is because there is particulat in the fill valve or mineral buildup and internally it doesnt always properly seal so it can run intermittently or all the time.
All the parts on the TOTO ultramax are warranteed for 5 years so keep that in mind if it applies.
Remove the tank lid when you hear the fill vave working and look at the water level. If the water level is below the top of the white plastic tube that the flapper is connected to (often called the overflow tube), then you have a bad flapper. If the water level is going over the top of the tube then you have a defective fill valve.
Out of warranty fill valves can easily be replaced with a Lavelle "Quiet fill" available at most hardware or plumbing stores or online.
This valve is what Toto uses in most of their toilets and it is only the removeable cap that is different (subliminal advertising maybe)
Aug 08, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Dec 31, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Changed the flapper on my toto toiet and yet still there is a hissing from the fill valve, any suggestions?
Oct 21, 2009 | Toto Ultramax One Piece Elongated Toilet...
My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
Aug 16, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Water continues to drip into overflow tube after fill
This is normal, though not so if it is excessive. Try adjusting the fill valve (there is either a ballcock or a float that surrounds the fill valve). With the ballcock, there is a screw at the top of the fill valve to lower the arm, on the other there is a metal clip to pinch and move the float with a large plastic screw for fine tuning.
Jun 26, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Toto 1.6 gpf won't stop running
1-check water level make sure it doesnt fill over flush valve.2-check handle make sure its not sticking and chain isnt catching on anything when flushed.3-replace flapper i like KORKY flappers. the red ones. like 6$
Jun 20, 2009 | Washing Machines
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
I have a toto toilet. After flushing it is taking a very long time to fill up.
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Mar 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
Toto ST454E Eco Drake II E-Max Toilet Tank Logo
217 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
